It is currently Wed Aug 26, 2026 4:05 am
 Post subject: my plugin to import a text file to layers, currently alpha version
PostPosted: Mon Jul 31, 2017 3:16 am  (#1)
It takes a newline delimited utf-8 file and imports each paragraph to a text layer. Not all options are implemented, but the main functionality has been, what is left to do are the vertical alignment and font/later size shrink/expansion functionality. I will get to that as soon as I finish work on another plugin for automated layer processing. Also simple markdown for the bold, italic, etc... styling is on the todo list for this plugin.
There must be a single line with "=====" between each paragraph, or you can use another delimiter such as empty to separate them by a single blank lines.
File comment: the plugin
import_text.py.zip [3 KiB]
Downloaded 275 times
 Post subject: Re: my plugin to import a text file to layers, currently alpha version
PostPosted: Mon Jul 31, 2017 7:17 am  (#2)
Works perfectly for me, thanks, great script!
I noticed there was an error if I tried to use a document that included non-Latin characters, but it's not a huge problem.. still works fine with clear parameters :)
PostPosted: Mon Jul 31, 2017 11:15 am  (#3)
This is good for lyrics, poems and such, can't wait for the updated version!
One thing I was wondering, is it suppose to import each paragraph as separate layer? I got every time one text layer only.
Thank you.
PostPosted: Mon Jul 31, 2017 8:14 pm  (#4)
thanks for the feedback double oh one,
Yeah, if you send ,me a failing sample I will see about fixing the latin character problems. I also noticed a strangeness with some characters. Seems like the utf8 decoding is not doing what I expected.
PostPosted: Mon Jul 31, 2017 8:19 pm  (#5)
Nidhogg,
Yeah maybe not clear.... if you use an empty delimiter you still need a single blank line between them, in other words that would be two carriage returns:
first bit of text.
second bit of text.
this will be a seperate layer then the first bit.
Also I was lazy to handle \r\n, so I will be fixing that in a later version. I expect I will get to that in the next few days. The "text seperator" field defaults to "=====" which would be:
first bit of text.
second bit of text.
And yes I have not done intensive testing on this, just for my own purposes so far as it is still at alpha. Once I get the rest of the features in I will do some better testing and documentation.
