It is currently Wed Aug 26, 2026 3:18 am
 Post subject: Request for script - Guillotine + Watermark
PostPosted: Sat Sep 02, 2017 2:29 am  (#1)
Hi everyone,
I perform a very repetitive task which I would like to automate.
I have a lot of PDF files, that I need to cut in pieces, watermark (based on name of source file) and then save them back as PDF. For example
This is the source file called Sample.PDF
I insert 2 horizontal guides to divide the file in three areas (the guides are always horizontal). They location of the guides varies from file to file.
Then I use the Guillotine tool to split the file in 3 files. Each of these files have to be watermarked at the bottom-nidele as Sample_00, Sample_01, Sample_02 and saved as Sample_00.pdf, Sample_01.pdf and Sample_02.pdf respectively. The output is as follows.
I have been trying to automate the following steps
1. Run Guillotine
2. Add watermark (format Sample_nn) near the middle bottom of the page.
3. Save files as Sample_nn.pdf in the same directory as the source file.
I am afraid I don't enough Scricpt-Fu to be able to do it.
Could any one of you assist please? Much appreciate your help !
