It is currently Wed Aug 26, 2026 3:19 am
 Post subject: Windows Gimp 2.9.6 Liquid ReScale plugin
PostPosted: Thu Sep 07, 2017 9:43 am  (#1)
Liquid Rescale is supposed to be included in Gimp 2.9 sometime, until then.
This came up on another forum, but since there are now some Windows Gimp 2.9.6 users here, might be some use.
64 bit Liquid Rescale plugin. I am sure Rod can compile it, but for others, this came from various Partha 64 bit Gimp 2.8 packages you can dig up on the internet archive.
3 files gimp-lqr-plugin.exe plug_in_lqr_iter.exe liblqr-1-0.dll
You can put them all in your plug-ins folder and it works, but strictly liblqr-1-0.dll should go in Gimp 2.9\bin folder
Not absolutely necessary but if not already done, avoid all those deprecated procedure warnings, add --pdb-compat-mode=on to the Gimp 2.9 shortcut.
Does it work, it does here:
Not the best of examples, but there it is:
Not sure if this is version 0.7.1 or 0.7.2 the files go back to around 2013 so might be 0.7.2
gimp-lqr-plugin.zip [116.86 KiB]
Downloaded 381 times
 Post subject: Re: Windows Gimp 2.9.6 Liquid ReScale plugin
PostPosted: Fri Sep 08, 2017 7:29 am  (#2)
Works a treat here Rich (Windows 10 64 bit).
Thank you! :)
I don't think i need to compile it. Besides i would have to gather all the recent development libraries and i really don't wanna. LOL.
Placed all files (including DLL file) in the USER/Rod/AppData/Roaming/GIMP/2.9/Plug-ins folder.
No errors or warnings.
PostPosted: Fri Sep 08, 2017 5:14 pm  (#3)
Thank you! :)
I don't have a Plug-ins folder at the aforementioned location.
The only Gimp User Plug-ins Folder I have is at,
Users\Wallace\.gimp-2.8\plug-ins.
The plug-in works,
when placed within my Users\Wallace\.gimp-2.8\plug-ins folder.
Also no errors or warnings when called for.
PostPosted: Fri Sep 08, 2017 11:29 pm  (#4)
Thank you! :)
The plug-in works,
This plug-in is for GIMP-2.9.6. :)
If you install GIMP-2.9.6 you will find the directories i mentioned above.
PostPosted: Fri Sep 08, 2017 11:34 pm  (#5)
I'm still using GIMP-2.8.
Didn't realise GIMP-2.9.6 changed the User Folder location.
:oops:
PostPosted: Sat Sep 09, 2017 7:32 am  (#6)
:oops:
Yeah that threw me too when i first installed it. What's worse is when you install Parthas version it COPIES the resources directory for GIMP-2.8 and most of those plug-ins and scripts are deprecated. :) His version tossed out so many executable errors i thought my computer had lost its mind. LOL
PostPosted: Sat Sep 09, 2017 7:41 am  (#7)
That's a major change to the User Folder.
There must be a change log or release notes,
but who reads those things anyway.
PostPosted: Sat Sep 09, 2017 9:32 am  (#8)
Migrating Gimp profiles when upgrading is not new. The same occurred with Gimp 2.6 -> Gimp 2.8
Before installing Gimp 2.9.6, temporarily rename your Gimp 2.8 profile to prevent this.
The use of the Window 'Roaming' folder, as I understand it, is conforming to Windows behaviour, that is where user settings are supposed to be held. The same is true in linux where the Gimp 2.9.x profile is now in ~/.config/GIMP/2.9
My advice, make your own easily accessible folders and add them to the relevant folder paths.
Mentioned before, to avoid all those deprecated procedure warnings run Gimp 2.9 with the --pdb-compat-mode=on switch.
Gimp 2.9.6 is a development version, No 32 bit support, do not expect those old compiled plugins to work.
PostPosted: Sun Sep 10, 2017 6:10 am  (#9)
For interested.
Liquid Rescale vr.0.7.2 64-bit version compiled for Gimp 2.8 Windows. Tested under Gimp 2.9.5 portable.
gimp-lqr-plugin-0.7.2_win64.zip [131.78 KiB]
Downloaded 316 times
PostPosted: Tue Sep 12, 2017 10:57 am  (#10)
Thanks pogogogo! :)
