It is currently Mon Sep 14, 2026 11:17 am
 Post subject: gimp-plugin-export-layers, help please!
PostPosted: Sat Sep 23, 2017 9:56 am  (#1)
Hi!
I am trying to save my work as PNG multiple layers for an animation inside a video I will do on Lightworks. I was planning on using GIMP to do this. But I am having trouble installing the plugin. I am illiterate as far as programming goes and I do not know why this is not functioning. :gaah The menu doesn't appear at all in Gimp. Here is a resume of what I have and what I did. Any kind of help is welcomed.
I have: 64bit Windows 10, Python 2.7.22 and Gimp 2.8
I uninstalled Gimp. Then installed Python, then reinstalled Gimp.
In GIMP, under filters, Python-fu, console I get this:
"GIMP 2.8.22 Python Console
Python 2.7.10 (default, May 23 2015, 09:40:32) [MSC v.1500 32 bit (Intel)]
So I think Python is recognized by Gimp. I copied the plug-in files for the extension here:
C: \Utilisateurs\Nathalie\ .gimp-2.8\plug-ins
The files copied are:
export_layers (file)
pygimplib (file)
exportlayers.py
Can someone tell me what I did wrong or what I need to check? I like working with GIMP but I need to be able to export animation.
THANK YOU!
 Post subject: Re: gimp-plugin-export-layers, help please!
PostPosted: Sat Sep 23, 2017 11:01 am  (#2)
1. No need to install Python in Gimp 2.8.x Gimp already contains the required python libraries. (You have looking at too many old Gimp 2.6 tutorials ;) )
2. That plugin has never worked for me. At best it crashes.
If you do need to try it, there is a whole folder export_layers + a single file export_layers.py that goes in your Gimp profile C:\Users\yourname\.gimp-2.8\plug-ins I think that is what you indicated in your post.
If it works, the menu entry will be bottom of the Files menu.
An alternative: http://registry.gimp.org/node/25029 download the file anitools.py.txt rename it to a plain anitools.py put that in your plugins folder. looks like this: https://i.imgur.com/Ke3efdx.jpg
Exports png's in the form 001.png 002.png ....
PostPosted: Sat Sep 23, 2017 11:25 am  (#3)
Thanks ! :hi5 :yes
The alternative solutions works A1!
Now I can concentrate on my project!
Cheers mate!
PostPosted: Sat Sep 23, 2017 7:16 pm  (#4)
I use "Export Layers preserving names" by paynekj who is on this fourm. I exports all layers as png's using the layer names to name the file. I am not sure where I got it from, but someone here should know.
PostPosted: Thu Jun 03, 2021 9:05 pm  (#5)
As this plugin is out dated or may be it is inactive on current issues, I made scripts for the same purpose. Please find it in Gimp Scripts - Export layers - Github -> desmarty/gimp_script . (This is an essential part of gimp. So I had to develop it by myself. It is a script, so it may not be broken in future releases of gimp. I am working on other essential modules for gimp too. Hope it is helpful to someone. Thank you)
