It is currently Tue Aug 25, 2026 8:22 pm
 Post subject: Script to save already open png file and exit
PostPosted: Fri Oct 06, 2017 4:58 pm  (#1)
Hi,
I have written a simple script in Scene or .scm to save an already open filename to png format and then exit gimp.
Sounds simple enough but i'm struggling.
I can't manage to get the parameters in "file-png-save" or somewhere else right.
All it has to do is save the already open png file and exit.
I'm fairly sure the below code is rubbish, so please liberally delete as necessary
Thanks
(define (script-fu-save-png Image layer)
   (gimp-displays-flush)
   (file-png-save RUN-NONINTERACTIVE Image layer filename filename FALSE 9 FALSE FALSE FALSE FALSE FALSE)
   (gimp-quit)
(script-fu-register
   "script-fu-save-png"
   "<Image>/Save PNG & Exit"
   "Save PNG file and exit GIMP."
   "kes"
   "kes"
   "October 2017"
   "RGB*, GRAY*, INDEXED*"
   SF-IMAGE         "Image" 0
   SF-DRAWABLE   "Layer" 0
 Post subject: Re: Script to save already open png file and exit
PostPosted: Fri Oct 06, 2017 6:29 pm  (#2)
try this:
   (define filename (car (gimp-image-get-filename Image)))
   (gimp-quit 1)
(script-fu-register
   "kes"
   "kes"
   "October 2017"
   SF-IMAGE         "Image" 0
TinT
PostPosted: Sat Oct 07, 2017 3:07 am  (#3)
There is a shorter script: Ctrl-E, Ctrl-Q, Ctrl-D. :)
PostPosted: Sat Oct 07, 2017 6:58 am  (#4)
Thanks @trandoductin. That did it. Thanks
PostPosted: Sat Oct 07, 2017 6:59 am  (#5)
Thanks @ofnuts. That's not the way I want to do it.
PostPosted: Sat Oct 07, 2017 7:13 am  (#6)
Is there a way I can attach a custom shortcut key to that new script menu item within gimp e.g. CTRL-X, or some other available shortcut sequence.
--> I figured it out guys. I moved the Script menu item "save PNG & Exit" into File, and was able to access it under > Edit > Keyboard shortcuts <--
Thanks for your help
PostPosted: Sat Oct 07, 2017 8:57 am  (#7)
I've improved the idea and am getting the hang of this more.
But I'm back to being unable to save again.
What you see works until "file-png-save" at the end.
I've tried to re-define the Image, Layer & Drawable though have clearly not succeeded. They are now commented out.
After merging the three layers, why can't I save them?
I've read that Python-Fu is easier to use. Would this easier to convert to Python?
   (define drawable (car (gimp-image-get-active-drawable Image)))
   (script-fu-round-corners Image drawable 20 TRUE 0 0 15 TRUE FALSE)
   (gimp-image-merge-visible-layers Image 0)
   ;(define layer (car (gimp-image-get-layer Image)))
   ;(define drawable (car (gimp-image-get-active-drawable Image)))
   ;(gimp-quit 1)
(script-fu-register
   "<Image>/File/Save PNG & Exit"
   "kes"
   "kes"
   "October 2017"
   SF-IMAGE         "Image" 0
PostPosted: Sat Oct 07, 2017 9:39 am  (#8)
instead of
you need to set layer to be the result of the merge like this
(set! layer (car (gimp-image-merge-visible-layers Image 0)))
Oh yeah python (in my opinion is much easier).
TinT
PostPosted: Sat Oct 07, 2017 9:55 am  (#9)
@trandoductin That worked. Thank you
