It is currently Tue Aug 25, 2026 1:29 am
 Post subject: Does exist an anti-aliasing script?
PostPosted: Sun Jan 14, 2018 4:49 pm  (#1)
I'm wondering if there exist an ant-aliasing script for Gimp? Example: Alpha to selection layer-shrink selection 1 pixel-invert selection-feather selection 5 pixels, then delete.
Sure I can do this manually, but a simple script to do those functions would be a big time saver...
 Post subject: Re: Does exist an anti-aliasing script?
PostPosted: Sun Jan 14, 2018 6:14 pm  (#2)
Would seem like a simple script to create.
Perhaps trandoductin will chime in and offer his assistance with this.
PostPosted: Mon Jan 15, 2018 4:23 am  (#3)
Hi racer, I recently used G'Mic > Repair > remove hot pixels to do an antialiasing-type task.
There is also Filters > Enhance > Antialias but it's almost a no show.
Cheers. :)
PostPosted: Mon Jan 15, 2018 5:18 am  (#4)
The "remove hot pixels" filter does the trick. Thanks..
PostPosted: Mon Jun 11, 2018 10:15 pm  (#5)
You can try using G'Mic > Repair > Upscale [dcci2x] and then downscale to the original resolution (I suggest using waifu2x to do this). You will have to adjust with the color grading option afterwards (G'mix > Color > Color grading) because for some reason the image becomes dimmer after downscaling from the upscaled version (Do a side-by-side comparison of original before upscaling with dcci2x).
Here are my settings. I didn't use the color grading, just the value and saturation adjustments (this works fairly well).
PostPosted: Tue Jun 12, 2018 3:52 am  (#6)
Better yet, use the LUT method described here https://discuss.pixls.us/t/gimp-how-to- ... lut/1567/3
PostPosted: Wed Jun 13, 2018 5:24 am  (#7)
Here is some code in python-fu to turn your idea into a plugin.
I thought it might amuse you to have your very own filter entry in your own copy of Gimp.
Copy the lines into a text editor, save the file (perhaps as Racer_Anitalias_Selection) with the extension .py and save it to your plugin folder.
#!/usr/bin/env python
#-*- coding: utf-8 -*-
# Anti-alias request from Racer_X
# A very literal coding of the steps requested
# It works, but can easily go wrong if the user
# tries to apply the plugin with a selection
# on the non-active layer.
from gimpfu import *
def plugin_main(image, layer, shrink_amount, feather_amount):
    # Store the GIMP's settings so they can be later restored
    gimp.context_push()
    # Set start undo point
    pdb.gimp_image_undo_group_start(image)
    # active_layer = pdb.gimp_image_get_active_layer(image)
    # Find out if there is already a selection with
    has_selection_original,sx1,sy1,sx2,sy2 = pdb.gimp_selection_bounds(image)
    if not has_selection_original:
        # if there is not already a selection
      # find the currently active layer with
        if active_layer:
            # if there is an active layer
            # create a selection from the contents of the active layer with
            pdb.gimp_image_select_item(image, CHANNEL_OP_REPLACE, active_layer)
    else:
        # otherwise if there is an existing selection
        # make a note of it with
        current_selection = pdb.gimp_image_get_selection(image)
    # now that we have a selection
    # shrink the selection by the amount entered in the dialog UI with
    pdb.gimp_selection_shrink(image, shrink_amount)
    # and invert the selection with
    pdb.gimp_selection_invert(image)
    # then feather selection by the amount entered in the dialog UI with
    pdb.gimp_selection_feather(image, feather_amount)
        # if there was no selection to begin with
        # cut the inverted selection
        is_successful = pdb.gimp_edit_cut(active_layer)
    else:
        # and if there was an initial selection
        # Find the currently active layer with
    # Finally remove the selection outline with
    pdb.gimp_selection_none(image)
    # Remove undo point
    pdb.gimp_image_undo_group_end(image)
    # Restore the GIMP's settings to their original status
    gimp.context_pop()
register(
    "python_fu_Racer_AntiAliasing",
    "Simple Anti-aliasing",
    "Simple Anti-aliasing for selection on the active layer",
    "Skinnyhouse",
    "GPL",
    "2018",
    "<Image>/Filters/Racer Anti-alias selection on active layer...",
    (PF_SPINNER, "pf_shrink", "Shrink selection by:", 1, (1, 3000, 1)),
    (PF_SPINNER, "pf_feather", "Feather radius:", 5, (1, 3000, 1)),
    plugin_main)
main()
PostPosted: Wed Jun 13, 2018 5:47 pm  (#8)
Thanks Skinnyhouse, that script works perfectly for what I want to do.
