It is currently Tue Aug 25, 2026 2:12 am
 Post subject: : Update to Joined-up Text filter: now Version 2.16
PostPosted: Thu Feb 22, 2018 3:16 pm  (#1)
JoinedUpVersion216.zip [25.39 KiB]
Downloaded 370 times
The zipped folder contains only the filter plugin. If you need the associated joined-up fonts search for version 2.15 and install from there.
Download and install the plugin to your plugin folder after removing the old one.
Here are two links to two solutions that work well when using long dialog boxes, like the one with this filter, with your python plugins Other solutions are available:
Link to post detailing JAZZON's solutions for scrolling py script user interface. Post #1:
viewtopic.php?f=9&t=13714
and a link to Bytes and Pixels solution via Rod. Post #10:
viewtopic.php?f=9&t=14502&p=200197&hilit=scroll+python+interface#p200197
Version 2.16 makes the jitter option available to text along a path without having to first have a custom angle of rotation applied: An oversight on my part.
Filter Helpsheets now available here:
PDF help sheets v216.zip [728.05 KiB]
Downloaded 328 times
and here:
PDF help sheets v216 - Part 2.zip [630.66 KiB]
Downloaded 319 times
