It is currently Wed Aug 26, 2026 2:14 am
 Post subject: Resynthesizer plugin error message (Linux)
PostPosted: Wed Feb 28, 2018 11:12 am  (#1)
Hello everyone,
Just installed Resynthesizer 1.0 on Gimp 2.8 on Linux.
The plugin installed successfully and appeared in the menus, but returns an error when I make a selection and try to use it.
First I click Filters => Enhance => Heal Selection
and the Heal Selection menu appears.
There I choose my options and when I click OK I get the following message:
An error occurred running python_fu_heal_selection
error: procedure not found
More information:
  File "/usr/lib/gimp/2.0/python/gimpfu.py", line 736, in response
  File "/usr/lib/gimp/2.0/python/gimpfu.py", line 361, in run_script
  File "/home/tatsumaru/.gimp-2.8/plug-ins/plugin-heal-selection.py", line 148, in heal_selection
    pdb.plug_in_resynthesizer(timg, tdrawable, 0,0, useBorder, work_drawable.ID, -1, -1, 0.0, 0.117, 16, 500)
I also get one more error:
Calling error for procedure 'gimp-procedural-db-proc-info':
Procedure 'plug-in-resynthesizer' not found
Any idea what I am doing wrong? Why isn't it working?
I downloaded Resynthesizer 1.0 and extracted the contents in /home/user/.gimp-2.8/plug-ins
Then I made all files executable.
Thanks.
 Post subject: Re: Resynthesizer plugin error message (Linux)
PostPosted: Wed Feb 28, 2018 11:29 am  (#2)
tatsumaru wrote:
Hello everyone,
.....snip....
Thanks.
Which linux distro? What 'flavour' 32 or 64 bit?
Resynthesizer has been updated since version 1.0
You can try the attached files plugin-heal-selection.py resynthesizer resynthesizer_gui
Unzip, should already be executable but check, replace what you already have installed in your gimp profile ~/.gimp-2.8/plug-ins
resynth_pack_linux_64.zip [24.69 KiB]
Downloaded 529 times
PostPosted: Wed Feb 28, 2018 11:43 am  (#3)
rich2005 wrote:
tatsumaru wrote:
Hello everyone,
.....snip....
Thanks.
I downloaded your files and extracted them and now it's working. Thanks so much!
