It is currently Thu Aug 27, 2026 1:16 am
 Post subject: Looking for the 'Path Shape Creator' [Solved]
PostPosted: Tue Mar 20, 2018 8:06 am  (#1)
Not sure if it is a script or a plugin.
 Post subject: Re: Looking for the 'Path Shape Creator'
PostPosted: Tue Mar 20, 2018 8:15 am  (#2)
I think version 8 was the latest/last version
http://www.arakne.es/en/programming/pyt ... reator-v8/
PostPosted: Tue Mar 20, 2018 7:14 pm  (#3)
I didn't know about this plugin, thanks for the link. It works fine for simple shapes.
PostPosted: Wed Mar 21, 2018 8:37 am  (#4)
Thank you rich but I'm not sure it is the same one. Although I seem to have those files in my folders already I cannot find them in gimp any where. I have about 3-4 places where there is paths but none of them lead to shape creator.
I had two before and they worked side by side perfectly.
Dont know how many shapes this one does but I know the other one did about a dozen.
Square/rectangle, circle / sphere, polygons, heart, diamond, drop, spiral, flower, star, gear, grid and it had quite a few settings to make them smaller or larger, stroke colour etc
Checked the site again about installing them. All is well now and there is probably more too.
