It is currently Thu Aug 27, 2026 1:16 am
 Post subject: HIGHLIGHT Rel 0.03 von GnuTux
PostPosted: Sat Apr 21, 2018 11:46 am  (#1)
Hello,
I'm looking for the script
Highlight 0.03 from GnuTux.
Does anyone have a download option?
Best regards, Hardy
 Post subject: Re: HIGHLIGHT Rel 0.03 von GnuTux
PostPosted: Sat Apr 21, 2018 11:50 am  (#2)
Via the internet archive
https://web.archive.org/web/20170803173 ... highlight/
which takes you to the download
https://web.archive.org/web/20170803173 ... hlight.scm
PostPosted: Sun Apr 22, 2018 1:39 am  (#3)
Hello,
Thanks for the link!!!
Best regards, Hardy
PostPosted: Sun Apr 22, 2018 6:45 pm  (#4)
This script was originally written by Graechan but I'm wondering how long does the webarchive hold content from sites that have lapsed?
PostPosted: Mon Apr 23, 2018 3:59 am  (#5)
The web archive in itself does not expire anything but some links external websites are lost. Samj's for example.
In Gimp terms, can go back some way. This the old GUG (gimp user group) when it was very busy. https://i.imgur.com/giJAw5u.jpg
Halfway down the tutorials page: https://i.imgur.com/ACWqXf8.jpg
Which shows that very little is actually new. https://i.imgur.com/xBKUWNx.jpg
What happened to GUG? Killed off by spam, then the server closed.
PostPosted: Tue Apr 24, 2018 5:20 pm  (#6)
The big issue is that scripts can't be updated on the web archive. I know that 'Wills animation merge' is not working with Gimp 10.
There must be quite a few great scripts that are broken on Gimp 10.
