It is currently Thu Aug 27, 2026 2:28 am
 Post subject: GIMP 2.10 & plugin-heal-selection & plugin-heal-transparency
PostPosted: Sun Apr 29, 2018 11:05 am  (#1)
The heal plugins don't work in 2.10. Would any of our script writers out there be willing to fix these?
An error occurred running python_fu_heal_selection
File "C:\Program Files\GIMP 2\GIMP 2\lib\gimp\2.0\python\gimpfu.py", line 740, in response
File "C:\Program Files\GIMP 2\GIMP 2\lib\gimp\2.0\python\gimpfu.py", line 361, in run_script
File "C:\Users\sonoftime\AppData\Roaming\GIMP\2.10\plug-ins\plugin-heal-selection.py", line 148, in heal_selection
pdb.plug_in_resynthesizer(timg, tdrawable, 0,0, useBorder, work_drawable.ID, -1, -1, 0.0, 0.117, 16, 500)
error: procedure not found
An error occurred running python_fu_heal_transparency
File "C:\Users\sonoftime\AppData\Roaming\GIMP\2.10\plug-ins\plugin-heal-transparency.py", line 59, in heal_transparency
pdb.python_fu_heal_selection(timg, tdrawable, samplingRadiusParam, 0, orderParam, run_mode=RUN_NONINTERACTIVE)
RuntimeError: execution error
 Post subject: Re: GIMP 2.10 & plugin-heal-selection & plugin-heal-transparency
PostPosted: Sun Apr 29, 2018 12:27 pm  (#2)
I'm not sure if this is still the case with GIMP Version 2.10.
However,
some of the python_fu Heal plugins.
Require that the resynthesizer plugin is installed.
PostPosted: Sun Apr 29, 2018 8:35 pm  (#3)
Apparently, the 2.10 install copies over your existing fonts, brushes, plugins, scripts, etc. from 2.8. I ended up having two resynthesizers, which was causing error. Removing one fixed the issue.
PostPosted: Sun Apr 29, 2018 8:57 pm  (#4)
That's odd,
but at least the issue is fixed.
