It is currently Fri Sep 11, 2026 10:57 am
 Post subject: Chisel or Carve v. 1.3 Script for Gimp 2.10
PostPosted: Sun May 06, 2018 6:54 am  (#1)
Have patched version 1.3 of Chisel or Carve script for Gimp 2.10 if anyone needs to use it. Only minor adjustments needed - thankfully - since I don't do scripts.
chisel_for_2-10-0.zip [2.82 KiB]
Downloaded 487 times
 Post subject: Re: Chisel or Carve v. 1.3 Script for Gimp 2.10
PostPosted: Sun May 06, 2018 7:07 am  (#2)
Just tried your script, Skinnyhouse and get the following error. :0
PostPosted: Sun May 06, 2018 7:09 am  (#3)
Thanks. I find that only a handful of scheme scripts will work in Gimp 2.10. I may edit a few also...
PostPosted: Sun May 06, 2018 7:47 am  (#4)
I get the same error Lyle.
PostPosted: Sun May 06, 2018 8:16 am  (#5)
No idea why it works on my system and not yours...
My OS: Windows 10 64 bit
My Gimp 2.10.00 version: Downloaded directly from Gimp.org
My Windows scripts location: C:\Users\MyUserName\AppData\Roaming\GIMP\2.10\scripts
PostPosted: Sun May 06, 2018 8:22 am  (#6)
Works fine here too in Linux via Gimp 2.10 flatpak.
PostPosted: Sun May 06, 2018 8:27 am  (#7)
May be the issue is with the portable versions.
Works fine on standard 2.10.
PostPosted: Sun May 06, 2018 8:43 am  (#8)
Thanks chaps! I'll be more specific from now on.
PostPosted: Sun May 06, 2018 9:04 am  (#9)
It's possible since I'm using samj's portable. Possibly the way the script is calling out commands via a directory structure (i.e., path), maybe. Not a programmer so I've not looked at the Script-fu but may take a gander at this in another 11 hours (when I get back from my job; going to chill for a few minutes now before I have to get ready for work). Anyway, you all have a great day. :)
PostPosted: Mon Nov 16, 2020 9:53 am  (#10)
Can anyone help me with this script?
Unfortunately, this no longer works in 2.10.22
PostPosted: Mon Nov 16, 2020 10:38 am  (#11)
Try this version to see if it work and let me know please.
chisel.scm [8.95 KiB]
Downloaded 195 times
PostPosted: Mon Nov 16, 2020 10:55 am  (#12)
I had that one, it uses legacy layer modes, the one in this topic uses 2.10 layer modes.
The results are different.
PostPosted: Mon Nov 16, 2020 11:16 am  (#13)
Did you check the value of "Force"?
Default is 50%.
It COULD be responsible of the black looking gray.
(There is a "gimp-context-set-brush-force" available to a script)
PostPosted: Mon Nov 16, 2020 11:27 am  (#14)
Thank you Poncholo, this script works fine
PostPosted: Mon Nov 16, 2020 11:28 am  (#15)
The result is a little darker shadow with the Legacy Mode. There is only one "Layer Mode function" on line 49, "HARDLIGHT-MODE". Change it to: LAYER-MODE-HARDLIGHT, and you get the lighted shadow version.
Open the script Notepad++ and on Line 149 change it from:
(gimp-layer-set-mode varBevelLayer HARDLIGHT-MODE)
To:
(gimp-layer-set-mode varBevelLayer LAYER-MODE-HARDLIGHT)
PostPosted: Mon Nov 16, 2020 11:50 am  (#16)
Yeah should have figured it out, thanks. I had not played with skinnyhouse's version earlier.
PostPosted: Mon Apr 19, 2021 12:54 pm  (#17)
I really like this filter, and would like to know if it will continue to work in Gimp 3?
But ultimately it would be far more ideal if there was a GEGL filter to Bevel/Chisel. That would open the door to advance NDE in the future and give us real time previews and filter presets of it.
