It is currently Wed Aug 26, 2026 2:59 am
 Post subject: Paths between approximate script for GIMP
PostPosted: Tue May 22, 2018 10:34 am  (#1)
Will approximately turn any path (solid shape) into any other path (solid shape) with option to fill shapes with starting color and ending color for possibly animation.
Starting path and ending path can have different number of points because it does approximation by generating equal distance number of points instead of using control points (hence approximation).
More details here --> Paths between approximate script for GIMP
TinT
 Post subject: Re: Paths between approximate script for GIMP
PostPosted: Tue May 22, 2018 12:13 pm  (#2)
Looks like you're on a creative code fest. Super stuff T.
PostPosted: Tue May 22, 2018 12:22 pm  (#3)
Thanks, I don't know about creative code fest...
but yesterday i wanted to turn a rat into an elephant so I did script for path approximation part, but the filling in the path and the placement in spiral pattern I did manually for this piece:
Then later I added options to fill the paths with script.
Then I turned the placing in spiral part into a separate script... I thought maybe people might want to display animation frames as such who knows... :hehe
TinT
