It is currently Mon Aug 24, 2026 8:49 pm
 Post subject: chisel.scm on gimp 2.10
PostPosted: Tue May 29, 2018 4:43 am  (#1)
Only a small note.
I tried to use chisel.scm on samj's 2.10.2 pack, got one error on the parameter "VIRTUAL" used when calling plug-in-bump-map.
Simply replaced LINEAR with the equivalent value 0, and the filter completes the run without any additional error.
Pls note: I didn't deeply test it, but I tought this simple comment deserves a post, in case someone is tempted to use chisel.scm:
replace LINEAR with 0 at statement (filter line) # 148
so you can use it.
 Post subject: Re: chisel.scm on gimp 2.10
PostPosted: Tue May 29, 2018 4:58 pm  (#2)
Yes that works nicely, thanks. Tried it in both appImage and flatpak. It didn't work before this simple modification.
PostPosted: Tue May 29, 2018 7:00 pm  (#3)
Thank you, Dinasset. I tried to use Chisel and Carve and could not get it to work. Will try your fix.
Edit: I ran it several times after adding your fix. No problems at all!! Thank you so much!!!!
Using Windows 10. 64 bit Gimp 2.10 (Samj)
PostPosted: Fri Jun 01, 2018 1:45 am  (#4)
A friend of mine (running Gimp 32bits) told me that the mentioned simple change did not work (still getting errors on compatibility issues).
Hence I decided to replace those statements which have non-2.10 Language (FILL, MODE) and prepared an amended version, which was double-checked without errors.
Hence I post it here for those interested.
chisel - dn.scm [9.39 KiB]
Downloaded 315 times
PostPosted: Fri Jun 01, 2018 1:48 am  (#5)
PS: remove the previous version before installing this one, because the registering function is the same (hence you would have a duplicated entry)
script-fu-register "script-fu-chisel"
PostPosted: Fri Jun 01, 2018 8:45 am  (#6)
Thank you so much Dinasset. :tyspin
PostPosted: Fri Jun 01, 2018 5:02 pm  (#7)
What would be real great, is a list of non-compatible commands along with the correct replacements. That way I can modify problem scripts.
Example:
LINEAR = 0
PostPosted: Sat Jun 02, 2018 12:53 pm  (#8)
You can start GIMP with parameter:
gimp --pdb-compat-mode=warn
Then when GIMP is on run your script in question and it will give you a list of what's deprecated and by what to replace in the error console. You can then check the parameters of the procedure.
Regards
nelo
PostPosted: Sat Jun 02, 2018 8:59 pm  (#9)
Dinasset, is your new version for 32 bit only or can it be used for 64 bit also?
PostPosted: Sat Jun 02, 2018 10:29 pm  (#10)
It's OK for both 64 and 32 bits (I am on 64bits, I use it and it works)
PostPosted: Wed Jul 11, 2018 5:08 pm  (#11)
Thank you Dinasset! :bigthup :hi5
