It is currently Wed Aug 26, 2026 4:05 am
 Post subject: Arakne-stitch 3b
PostPosted: Fri Jun 29, 2018 1:02 pm  (#1)
Hi,
I am confused. I have switched to Mac and I cannot figure out how to put extra features in gimp-2.10-std.
I want to install arakne-stitch 3b, or something equivalent to stitch scans of large drawings.
Can someone direct me to the right page, or tell me how to do it?
I have looked at some old guides to installing plugins, but they didn't match what I see in my preferences or how script-fu wants to work. (Though I must say that a major caveat is that I have no f%&$@#n idea what I am doing, in general).
Any help greatly appreciated - head about to explode........ :gaah :)
Thanks,
Luke
 Post subject: Re: Arakne-stitch 3b
PostPosted: Fri Jun 29, 2018 8:22 pm  (#2)
Hi ordream.
The process is the same AFAIK across the platforms. Download your script/plugin and drag and drop or copy-n-paste into either the 'scripts' or the 'plug-ins' folder.
With the Arakne-stitch python script you need to check if it's 'executable' and if not make it so. This is just a tick on Linux but may involve fruit on an apple :)
PostPosted: Mon Jul 09, 2018 7:57 pm  (#3)
Thanks for the reply.
Ignoramus questions:
1) What is the difference between scripts and plugins?
2) How do you know which is which?
3) How do you check if a file 'executable?`
Hurrah.
PostPosted: Mon Jul 09, 2018 10:42 pm  (#4)
Plugins are binaries or python (.py). You place them in Plug-Ins folder
Scripts save .scm suffix and go to scripts folder.
Here's how you set permissions on Mac:
http://www.macinstruct.com/node/415
Or you can use application called BatChMod.
http://www.lagentesoft.com/batchmod/
PostPosted: Tue Jul 10, 2018 10:22 am  (#5)
Hi,
Problems I encountered:
1) In the `arakne-stitch3b.py´ and the `locales´files:
When I do the `get info´option, and I unlock the menu with my administration password I can see read and write options, but no execute option.
2) This is what what terminal says based on my interpretation of: `How to Modify Permissions with chmod´
Last login: Tue Jul 10 10:29:41 on ttys000
Lukes-Air:~ luke$ ls –l
ls: –l: No such file or directory
Lukes-Air:~ luke$ chmod 755 /Users/luke/Downloads/arakne-stitch3b/arakne-stitch3b.py
Lukes-Air:~ luke$
Am I misunderstanding the process?
Thanks,
Luke
