Now I know where I had seen this error from the earlier thread:
viewtopic.php?f=9&t=16486It was when trying to create a new paint brush with Edit>>Paste as>>New brush...
This may have been present in the Windows (64 bit) versions of 2.10 from the beginning - currently using 2.10.4.
My fix (until they update script-fu) is to take a copy of the 'paste-as-brush' script from the gimp scripts folder and add a new line to define the number to string conversion before saving it to my user Scripts folder (taking precedence over the original version). This is definitely out of my league but it works.
Information gathered from stackoverflow.com:
You can rebind variables and monkeypatch top level standard library functions in Scheme, but I don't think you can unbind top level variables. Maybe there is some library file that isn't loading right.
My TinyScheme in GIMP 2.6.8 on OS X executes number->string just fine.
number->string is defined in share/gimp/2.0/scripts/script-fu.init as
(define (number->string n) (anyatom->string n number?))
so you could just run that code to rebind the variable.
Link to stackoverflow page:
https://stackoverflow.com/questions/248 ... scripting#
