It is currently Wed Aug 26, 2026 6:34 pm
 Post subject: Has scrollable interface for scheme scripts in GIMP 2.10 been solved?
PostPosted: Tue Aug 21, 2018 10:51 am  (#1)
If it hasn't been solved (since I couldn't compile the source because config.h is not found anywhere).
here's a work around.
The downside is that an individual .py has to be written for each scheme script. The plus side is gimpfu.py scrollable py plug-ins work for 2.10 and there aren't too many scheme scripts that need the scrollable interface (at least I haven't seen too many).
more details here => https://gimplearn.net/viewtopic.php/Scr ... 856#p19856
TinT
 Post subject: Re: Has scrollable interface for scheme scripts in GIMP 2.10 been solv
PostPosted: Tue Aug 21, 2018 11:01 am  (#2)
Also it's another excuse/encouragement to create new scripts in python and not scheme. :D
TinT
PostPosted: Tue Aug 21, 2018 1:09 pm  (#3)
Tin, I do not know about the regular 2.10 gimps but I am using Samj's and there is a script fu.py included in her system plug in folder already included. It takes care of even long boxes like BRL.
I wish there was one for long .py programs but there is not, although that is not a common problem like with the Script fu.
PostPosted: Tue Aug 21, 2018 3:23 pm  (#4)
the one you gave me called gimpfu.py takes care of long .py programs but I don't know if it'll work for Samj's build...
TinT
PostPosted: Thu Aug 23, 2018 12:38 am  (#5)
I guess only one way to know. I will try it and see what happens.
