It is currently Tue Aug 25, 2026 12:53 pm
 Post subject: 12/13 Top Downloads from gimpscripts.com
PostPosted: Tue Aug 21, 2018 1:15 pm  (#1)
12/13 Top Downloads from gimpscripts.com and their compatible version on GIMP 2.10 on GL
One that doesn't work belongs to ofnuts, I don't understand enough of what's going on to or why it doesn't generate anything except transparent layers in 2.10.
TinT
 Post subject: Re: 12/13 Top Downloads from gimpscripts.com
PostPosted: Tue Aug 21, 2018 2:30 pm  (#2)
Works ok here:
PostPosted: Tue Aug 21, 2018 3:22 pm  (#3)
Oh that's weird... I have GIMP 2.10.0 flatpak install for Linux.
TinT
PostPosted: Wed Aug 22, 2018 1:39 am  (#4)
That 2.10.6 is flatpak, 'buntu 16.04, updated from 2.10.4
I did find I had to create a new gimp profile, some incompatibility in settings perhaps. Otherwise works fine.
How to update, the obvious: flatpak update in a terminal will tell what is possible.
PostPosted: Wed Aug 22, 2018 2:07 am  (#5)
The Adjustment Layer scripts are 2.10.6 compatible.
Here's the link: gimpchat.com/viewtopic.php?f=9&t=13573
Are the scripts you have compatible with 2.10.6? If they are is there a way to put them all in a zip file for easier access?
PostPosted: Wed Aug 22, 2018 4:17 am  (#6)
Neon-path is deprecated anyway, in 2.10 you can use ofn-gradient-along-path for cleaner results (uses the new 2.10 API to stroke paths).
PostPosted: Wed Aug 22, 2018 9:52 am  (#7)
rich2005: Thanks I updated mine to 2.10.6 using that comment `flatpak update` so that's great.
But the neon path still show blank. I give up. :D
mackenzieh: Looks like dinasset is already attacking those adjustment layers scripts for you.
I can't say for sure if these top scripts will work for 2.10.6 but I tested them on 2.10.0 so chances are they should work for 2.10.6 since I am not expecting any new constant name introduction in 2.10.6 but probably just bug fixes for 2.10 series.
I don't want to create zips of multiple scripts because then which one should i include and which one should i exclude. You might only use 2 of 13 scripts. Also if there needs to be new version of one script then the zip is now outdated and has to be updated too so I don't want to maintain zipped versions of scripts.
ofnuts: Thanks for letting me know that's it deprecated...I'll update the list to tell people to use your gradient along path...just downloaded it and tried ...works like magic in my 2.10.6.
TinT
PostPosted: Wed Aug 22, 2018 12:48 pm  (#8)
Oh, okay. That makes sense. Thanks, Tin.
PostPosted: Wed Aug 22, 2018 2:20 pm  (#9)
No problem... if you want a zip of pretty much everything I think omg has that :D
TinT
PostPosted: Thu Aug 23, 2018 1:53 pm  (#10)
Yes, I would like a zip. It suites me better than just going through links.
PostPosted: Thu Aug 23, 2018 3:34 pm  (#11)
Incidentally, I don't maintain the scripts on GimpScripts. GnuTux copied some of my scripts on GS, which is completely OK since they are GPL-licensed, but that doesn't mean I'll maintain them there.
Btw, gimpscripts.com no longer exists in the DNS servers?
PostPosted: Thu Aug 23, 2018 6:06 pm  (#12)
You mean if I copy your script locally to my harddrive, you won't maintain that copy either? kidding :D
TinT
