It is currently Tue Aug 25, 2026 4:41 pm
 Post subject: Rotate layer in script
PostPosted: Tue Aug 28, 2018 10:01 pm  (#1)
Hello Everyone: I am new to Gimp scripts and I am writing a Python script in which one of the steps is to rotate a layer by 10 degrees. If I rotate the layer in Gimp using the Rotate tool, specifying an angle of 10 produces the desired result i.e. the layer is rotated clockwise by 10 degrees. However, I cannot duplicate this using the pdb.gimp_item_transform_rotate procedure - specifying an angle of 10 rotates the layer somewhere around 220 degrees.
What am I doing wrong?
Thanks. . .
Tony N.
 Post subject: Re: Rotate layer in script
PostPosted: Tue Aug 28, 2018 11:47 pm  (#2)
angle1 = 10.0
rotation = (angle1/180.0)*3.14159 #converting to radians
rotated1 = pdb.gimp_item_transform_rotate(Drawable, rotation, True, Drawable.width/2, Drawable.height/2)
PostPosted: Wed Aug 29, 2018 1:39 am  (#3)
angle1 = 10.0
math.pi is better than 3.14159
PostPosted: Wed Aug 29, 2018 6:33 am  (#4)
Thanks Ofnuts.
PostPosted: Wed Aug 29, 2018 9:29 am  (#5)
dinasset, ofnuts: Yes, that worked - thanks so much.
Regards. . .
Tony N.
