It is currently Sat Aug 29, 2026 6:27 am
 Post subject: ICCII Layer FX for 2.10
PostPosted: Wed Sep 05, 2018 6:40 am  (#1)
Okay. I tried to be sharper this time, all parameters should be fixed.
If not, you can give me virtual slap.
I like this script, you can use your preferred font instantly with "text creator" and apply basic layer effects easily.
Menu entry is on top, "ICCII FX" and default font Futura HV BT.
You can change them in lines 1513 & 1521 if want.
I keep the python and scm layer effects on main menu too, because they are essentials.
iccii-layer-effects.scm [55.01 KiB]
Downloaded 484 times
 Post subject: Re: ICCII Layer FX for 2.10
PostPosted: Thu Sep 06, 2018 3:41 am  (#2)
Never heard of this script. Can you post a screenshot of what it does? I'd hate to D/L, install, then delete 2 mins later. Is it the same as LayerFX?
PostPosted: Thu Sep 06, 2018 5:06 am  (#3)
Yes it is Layer FX with custom settings and added effects:
- vignette
- border
- style sample 1 & 2
- text creator
Style sample 2 preview, disabled satin layer.
PostPosted: Thu Sep 06, 2018 6:17 am  (#4)
Running fine on my portable Samj 2.10.01
Nidhogg thank you !! :bigthup
PostPosted: Thu Sep 06, 2018 9:52 am  (#5)
Youre welcome TicTac. And BIG BOO to Windows!
Why is it that I had no issues on Xubuntu, but on Windows I get more error pop-ups?
Attached new version.
iccii-layer-effects.scm [55 KiB]
Downloaded 485 times
PostPosted: Thu Sep 06, 2018 11:50 am  (#6)
Hi Nidhogg,
Well ... I'm using windows 10, and I have not had any error messages.
Is it really necessary to download this new version? :roll:
thx
PostPosted: Thu Sep 06, 2018 1:30 pm  (#7)
The new version works for me.
Windows 10, Gimp 2.10.6
The other version threw errors.
Thanks, it is terrific !
PostPosted: Thu Sep 06, 2018 2:58 pm  (#8)
Hi Nidhogg,
thx
I believe you should run into error using either of the style samples with the first file I posted.
You're welcome SeriousTom.
PostPosted: Wed Jan 02, 2019 3:37 am  (#9)
Hi.
On my windows 10 and Gimp 2.10.8
This script don't work.
I resume :
- Text creator : ok
- Add border : Erreur lors de l’exécution de script-fu-layer-effects-add-border :
Error: eval: unbound variable: TRANS-IMAGE-FILL
- Add vignette: Erreur lors de l’exécution de script-fu-layer-vignette :
Error: Procedure execution of gimp-context-set-gradient failed on invalid input arguments: Impossible de trouver le dégradé « FG to Transparent »
- Bevel & Emboss : No erreur message but no result in the picture.
- Color Overlay : Erreur lors de l’exécution de script-fu-layer-effects-color-overlay :
- Drop Shadow : ok
- Gradient Overlay : Erreur lors de l’exécution de script-fu-layer-effects-gradient-overlay :
etc...
Have you a version for 2.10.8 ?
Best regards.
PostPosted: Wed Jan 02, 2019 4:06 am  (#10)
It seems you are NOT using the version posted on post #5: there is NO TRANS-IMAGE-FILL statement inside that one.
Pls double-check or re-download/install the one posted at #5.
PostPosted: Wed Jan 02, 2019 4:15 am  (#11)
addendum:
-tested ALL the effects, all are working.
-about "Impossible de trouver le dégradé « FG to Transparent »" that's likely due to the fact that you are NOT using English as Language, pls change the name into your French equivalent (you see it on the desktop)
PostPosted: Wed Jan 02, 2019 4:31 am  (#12)
Hi thank you for this #5 It is Correct
But i have a " Erreur lors de l’exécution de script-fu-layer-vignette :
Error: Procedure execution of gimp-context-set-gradient failed on invalid input arguments: Impossible de trouver le dégradé « FG to Transparent »"
In Add Vignette.
And "Erreur lors de l’exécution de script-fu-layer-effects-styles-sample1 :
Error: Procedure execution of gimp-context-set-gradient failed on invalid input arguments: Impossible de trouver le dégradé « FG to Transparent » "
In Style Sample 1.
Best Regards
I don't understand your request about "FG..."
I have this :
PostPosted: Wed Jan 02, 2019 4:50 am  (#13)
If you click on the Gradient tool panel on the right, you should see how those types are translated into French.
I attach a screenshot.
Beware, I use English, this is just to show you where to look.
Once you know how it is defined in French, use that text in the filter.
PostPosted: Wed Jan 02, 2019 4:55 am  (#14)
I started GIMP in French, so you can see:
Use "PP vers Transparent" in the script parameter.
PostPosted: Wed Jan 02, 2019 5:01 am  (#15)
Wait, I look into the filter code…
Done, it is hard-coded, so you need the filter "translated" into French for some effects.
If you like I can try to do it for you
PostPosted: Wed Jan 02, 2019 5:08 am  (#16)
:tyspin
Well I have "edit" the scn and change this.
No error message now
Thank you very much.
Have a good day.
PostPosted: Wed Jan 02, 2019 5:14 am  (#17)
OK, glad you have it running.
PostPosted: Sun Jan 20, 2019 2:08 am  (#18)
Another solution for gradients (probably simpler - and also works for other scripts without having to change the code) is the addition (to gradients) of the English-language version.
These additional gradients should not be used in the English version.
ps. In fact, it script Iccii-Layer-Effects.scm use a lot of outdated procedures (only a few examples):
called deprecated procedure 'gimp-drawable-get-name'.
It should call 'gimp-item-get-name' instead!
called deprecated procedure 'gimp-image-add-layer'.
It should call 'gimp-image-insert-layer' instead!
called deprecated procedure 'gimp-round-rect-select'.
It should call 'gimp-image-select-round-rectangle' instead!
called deprecated procedure 'gimp-selection-layer-alpha'.
It should call 'gimp-image-select-item' instead!
called deprecated procedure 'gimp-selection-load'.
called deprecated procedure 'gimp-invert'.
It should call 'gimp-drawable-invert' instead!
called deprecated procedure 'gimp-image-lower-layer'.
It should call 'gimp-image-lower-item' instead!
called deprecated procedure 'gimp-ellipse-select'.
It should call 'gimp-image-select-ellipse' instead!
called deprecated procedure 'gimp-palette-set-foreground'.
It should call 'gimp-context-set-foreground' instead!
In Attachment (for testing):
- additional gradients English names,
- changed script (rename outdated procedures, change of location in the Gimp menu: Layer -> Layer FX (ICCII)
and added contex menu (right mouse button) in window "Layers Menu" -> Layer Effects FX
Gradients En.zip [1.2 KiB]
Downloaded 215 times
scripts_Iccii-Layer-Effects-210.zip [10.99 KiB]
Downloaded 235 times
PostPosted: Thu Dec 12, 2019 3:54 am  (#19)
Can someone please show an example of what Icci Layer Effects does and how to get it to work? I can't get it to work. The main one in this Layerfx that I can't seem to get to work is Satin.
PostPosted: Thu Dec 12, 2019 12:50 pm  (#20)
It's a bundle of custom LayerEffects with some additional stuff: vignette, border, satin.
There's also a simple text/logo creator and 2 different style samples.
