It is currently Tue Aug 25, 2026 4:40 pm
 Post subject: please fix a script for me
PostPosted: Tue Sep 18, 2018 11:09 am  (#1)
I have this 'make 3d' script that i use a lot.
Unfortunately it has one little flaw: it never appears in the 'Filters -> Repeat Last' list.
Can somebody tell me what code i need to add to make it work ?
        (script-fu-register
                  "script-fu-make-3d"                        ;func name
                  "make-3d"                                  ;menu label
                  "Makes a 3D representation\
          of the current (text) layer"              ;description
                  "Frans Rijven"                             ;author
                  "copyright 2009, Frans Rijven"             ;copyright notice
                  "Aug 11 , 2009"                          ;date created
                  ""                     ;image type that the script works on
        SF-IMAGE      "Image"           0
        SF-DRAWABLE   "Drawable"        0
        SF-VALUE   "Depth"  "6"
        SF-OPTION "Horizontal direction" '("Right" "Neutral" "Left")
        SF-OPTION "Vertical direction" '("Bottom" "Neutral" "Top")
        SF-OPTION "Half depth" '("none" "horizontal" "vertical")
        SF-VALUE   "Bump-direction:"  "90"
        SF-VALUE   "Bump-height:"  "45"
        SF-VALUE   "Bump-projection depth:"  "2"
        (script-fu-menu-register "script-fu-make-3d" "<Image>/Script-Fu")
        (define (script-fu-make-3d beeld laag diepte hrichting vrichting half brichting bhoogte bprojdiep)
      (gimp-image-undo-group-start beeld)
   (let*
         (orglaag (car (gimp-image-get-active-layer beeld)))
     (let*
         (werklaag (car (gimp-layer-copy laag TRUE )))
         (pos (car (gimp-image-get-layer-position beeld laag)))
         (nwpos (+  pos 1))
       (gimp-image-add-layer beeld werklaag nwpos)
     (let*
;         (nlaag 0)
         (baslaag (car (gimp-image-get-active-layer beeld)))
;        (baspos (car (gimp-image-get-layer-position beeld baslaag)))
         (lagenteller diepte)
        (focuslaag baslaag)
        (hwissel 0)
        (vwissel 0)
        (set! hrichting (- 1 hrichting))
        (set! vrichting( - 1 vrichting))
        (set! hwissel hrichting)
        (set! vwissel vrichting)
         (plug-in-bump-map 1 beeld baslaag baslaag brichting bhoogte bprojdiep 0 0 0 0 TRUE FALSE 0)
        (while (> lagenteller 0)
           (let*
              (focuslaag (car (gimp-image-get-active-layer beeld)))
               (werklaag (car (gimp-layer-copy focuslaag TRUE )))
               (laagpos (car (gimp-image-get-layer-position beeld focuslaag)))
              (nwpos (+ laagpos 1))
            (if (= half 2)
               (if (= vwissel 0)
                  (set! vwissel 0)
            (if (= half 1)
               (if (= hwissel 0)
                  (set! hwissel 0)
             (gimp-drawable-transform-2d-default werklaag 0 0 1 1 0 hwissel vwissel FALSE 0)
             (set! lagenteller (- lagenteller 1))
        (gimp-image-set-active-layer beeld baslaag)
        (set! lagenteller diepte)
           (gimp-image-merge-down beeld baslaag 0)
           (set! baslaag (car (gimp-image-get-active-layer beeld)))
      (gimp-image-set-active-layer beeld orglaag)
      (gimp-displays-flush)
      (gimp-image-undo-group-end beeld)
 Post subject: Re: please fix a script for me
PostPosted: Tue Sep 18, 2018 1:44 pm  (#2)
All I had to do was change image type to "RGB*"
   (let*
     (let*
         (nwpos (+  pos 1))
     (let*
;         (nlaag 0)
        (focuslaag baslaag)
        (hwissel 0)
        (vwissel 0)
           (let*
            (if (= half 2)
               (if (= vwissel 0)
                  (set! vwissel 0)
            (if (= half 1)
               (if (= hwissel 0)
                  (set! hwissel 0)
(script-fu-register
                  "RGB*"                     ;image type that the script works on
        SF-IMAGE      "Image"           0
TinT
PostPosted: Tue Sep 18, 2018 1:47 pm  (#3)
Quite a lot of time I do not use scheme.
One simple difference with respect to those I wrote in the past is that I always set the filter definition first and the filter registration afterwards, but this probably doesn't matter.
As Tin said, replace the null image type to something like RGB*.
PostPosted: Tue Sep 18, 2018 2:04 pm  (#4)
Oh, so easy :)
Thanks a lot trandoductin ! :yes
PostPosted: Tue Sep 18, 2018 2:19 pm  (#5)
There is a better 3D script that even uses Texture, created by one of the Gimpchat member and former owner "GnuTux". The website is not up, but I can share this wonderful Filter with you.
Filters-3d-extrusion.scm [15.83 KiB]
Downloaded 158 times
