It is currently Wed Aug 26, 2026 10:09 pm
 Post subject: Update to Custom Font Outlines for Gimp 2.10 to Version 0.05
PostPosted: Wed Sep 19, 2018 2:53 pm  (#1)
Custom_Font_Outliner_No_Colour_Selector_v005.zip [6.69 KiB]
Downloaded 248 times
I have updated Custom Font Outlines to version 0.05
Details here on GimpLearn:
https://gimplearn.net/viewtopic.php/Upd ... 623#p20623
 Post subject: Re: Update to Custom Font Outlines for Gimp 2.10 to Version 0.05
PostPosted: Wed Sep 19, 2018 3:06 pm  (#2)
Thanks a lot Skinnyhouse. :tyspin :coolthup
PostPosted: Thu Sep 20, 2018 1:47 pm  (#3)
Many thanks to you, Skinnyhouse, for all the time and effort you put into the art of creating custom fonts and for sharing them with us.
PostPosted: Thu Sep 20, 2018 3:10 pm  (#4)
Thanks - you're welcome as always.
PostPosted: Thu Sep 20, 2018 11:19 pm  (#5)
Hello Skinnyhouse
I can not click on the "OK" button it is down on the screen.
I need a "Scrolling Interface" for Gimp 2.10.06
Can you help me ?
Thanks
Doron
PostPosted: Fri Sep 21, 2018 12:38 am  (#6)
Link to options for scrollable py dialogs:
Post #8 for Gimp 2.10
viewtopic.php?f=9&t=13714&start=0
PostPosted: Fri Sep 21, 2018 2:20 am  (#7)
It did not work for me.
1) If you can please ADD a link to download the file?
2) Where to add the file?
Thanks
Doron.
PostPosted: Fri Sep 21, 2018 5:45 am  (#8)
I think we are using the same version of Windows so I cannot see why this does not add a scroll bar to plug-in dialogs ending in the .py file extension (not those ending with the .scm file extension).
The version of gimp 2.10.6 I use is the one downloaded directly from gimp.org.
The answers to your request for more information:
Q1: The replacement gimpfu file download is there in post #8.
Q2: I have successfully used this with each version of Gimp 2.10 placing it in this location:
C:\Program Files\GIMP 2\32\lib\gimp\2.0\python
If that location does not exist for you (or there are no original gimpfu files in that location) do a search in Windows File Explorer for gimpfu to find out where it is and use that one. If there are multiple locations (within Gimp) then you have no option but to try replacing each one (one at a time) to find out which one works for you.
PostPosted: Fri Sep 21, 2018 6:16 am  (#9)
For scrollable .py dialog boxes you need a gimpfu py plug in added to your system files (works better there than in user profile). Remember that this must be placed in the PYTHON folder, not the plug in folder
gimpfu_original_2pt10_ammended (4).zip [7.66 KiB]
Downloaded 238 times
C:\Program Files\GIMP 2.0\32\lib\gimp\2.0\python
For long .scm dialog boxes, a scriptfu file is needed. This should be placed in the system plug-ins folder. It is a folder with 2 files, just put the whole folder in the plug-ins folder.
C:\Program Files\GIMP 2.0\32\lib\gimp\2.0\plug-ins
script-fu.zip [189.63 KiB]
Downloaded 205 times
The pathway to the python and plug in folders for the system may vary somewhat if you are using a different version of GIMP.
PostPosted: Fri Sep 21, 2018 12:51 pm  (#10)
Pat625 wrote:
For scrollable .py dialog boxes you need a gimpfu py plug in added to your system files (works better there than in user profile). Remember that this must be placed in the PHYTHON folder, not the plug in folder
script-fu.zip
Sorry, but it did not help.
Doron.
