It is currently Fri Aug 28, 2026 8:42 am
 Post subject: Auto-text and filename
PostPosted: Fri Sep 21, 2018 9:48 am  (#1)
Hi,
Newbie here.. I want to create multiple images with a default background and some specific text on it. I also need to set the specific filename based on a unique id.
Example.
Is there a plugin or script that allows me to do that? Also, can I set the input with a CSV, JSON, or something similar?
Thank you in advance.
 Post subject: Re: Auto-text and filename
PostPosted: Fri Sep 21, 2018 1:17 pm  (#2)
I would say Gimp is the wrong tool.
Imagemagick will overlay text from a text file, something like this for a single image
magick convert back.png -gravity South -font Deutsch.ttf -pointsize 20 -annotate +0+5 @gc.txt 1.jpg
Best place to ask the question is https://www.imagemagick.org/discourse-server/ in the user section
PostPosted: Fri Sep 21, 2018 10:05 pm  (#3)
Hi germallon
Cut-out your fruit images and add an 'alpha channel' or a transparent background so you can use a common background.
Then 'Open as layers' for each fruit.
All layers should be the same size.
So now they are layers with the transparent hatching behind each fruit.
Then put your background at the bottom. (open as layer)
You will have to move it below the bottom layer of the stack.
Then Filters > Animation > combine background.
Finally,
File > 'Export Layers' and use PNG which will give each layer a different file name.
Rename as necessary.
