It is currently Sat Aug 29, 2026 6:15 pm
 Post subject: Custom Font Tools
PostPosted: Sat Sep 22, 2018 9:13 am  (#1)
Ok I surrender!
Custom Font Tools.zip [20.95 KiB]
Downloaded 243 times
I have split the custom font outlines filter into two parts - outlines and effects - to avoid the over-long dialog scenario. No scrolling needed.
The zipped file contains both of these files and an updated version of Custom Font Layer Names (or Labels) plus a copy of Layers from Fonts since they all now are accessible from the same filter menu path - Filters>>Custom Font Tools>>
It's up to you whether you keep the old ones or use the new - but all four py files need to be unzipped and copied into your user plug-in folder.
 Post subject: Re: Custom Font Tools
PostPosted: Sat Sep 22, 2018 1:16 pm  (#2)
Thank you so much for continuing your hard work. You are so innovative!
