It is currently Wed Aug 26, 2026 1:24 pm
 Post subject: BIMP 2.0 for Gimp 2.10
PostPosted: Fri Dec 07, 2018 2:17 am  (#1)
https://alessandrofrancesconi.it/projects/bimp/
Changelog BIMP 2.0:
-BIMP codebase has been updated to be natively compatible with GIMP 2.10, while it does not work anymore with GIMP <= 2.8.
-Added support to HEIF, XPM and JPEG2000 images
-Use GResources instead of Pixdata
-Many compiler warnings fixed
-Enhanced Win32 make procedure (needs MSYS2)
Unfortunately, this did not work on my old computer running Win Vista 32bit so I compiled with sources (for those interested in the attachment).
BIMP 2.0 for Gimp 2.10 Win 32bit Vista.zip [409.95 KiB]
Downloaded 347 times
 Post subject: Re: BIMP 2.0 for Gimp 2.10
PostPosted: Fri Dec 07, 2018 4:03 pm  (#2)
I'm always impressed by a Gimp plugin written in c. Good you compiled BIMP yourself. I would think about moving to 64bits when you get the hardware.
PostPosted: Sat Dec 08, 2018 4:17 pm  (#3)
Changelog BIMP 2.0:
Wow!!!!
You are my hero. (I know not how to compile)
PostPosted: Sat Dec 08, 2018 5:42 pm  (#4)
Will it work on 64 bit? If not, is there a 64 Bit version?
PostPosted: Sun Dec 09, 2018 5:30 am  (#5)
The BIMP 2 installer is 32 bit only. That does make it more "universal" Gimp from gimp.org will use both 32 bit and 64 bit plug-ins.
I have issues with that installer,
1) It installs in the system plugins folder rather than the Gimp user profile.
2) It puts a dependency pcre3.dll in windows\system32 folder - never a good idea. Gimp 2.10 already includes a version of that, so it is redundant.
The correct way for Gimp 2.10 is plugin and dependencies in their own folder, then that in the user plugins folder. See gimp_gmic installer for how it should be done.
Using a pure 64 bit Gimp such as Partha's version? You need a 64 bit BIMP and AFAIK the only one is from samj and that is the previous version, BIMP 1.18
see: https://samjcreations.blogspot.com/2018 ... ts_24.html
PostPosted: Sun Dec 09, 2018 1:55 pm  (#6)
Oh, okay. Thanks for the explanation.
Oh, okay.
