It is currently Wed Aug 26, 2026 6:29 pm
 Post subject: Glass Effect Text script
PostPosted: Tue Jan 01, 2019 4:32 am  (#1)
In this topic, the link indicated by Gnu Tux for Glass Effect Text V1.4 script is no longer valid:
http://gimpchat.com/viewtopic.php?p=108#p108
Where to find this script?
 Post subject: Re: Glass Effect Text script
PostPosted: Tue Jan 01, 2019 4:59 am  (#2)
Not the same, but you may give it a try.
glass_script_fu_runs_on_2_4_by_kward1979uk.scm [2.92 KiB]
Downloaded 442 times
PostPosted: Tue Jan 01, 2019 5:05 am  (#3)
@level_0
When a web site vanishes, you can sometimes find what you need using the internet archive: https://web.archive.org Copy the link and paste it into the search box. Click on one of the dates and with luck it takes you to a copy.
Can be slow in some cases so try this:
https://web.archive.org/web/20161017190 ... t-v1-4.zip
Do give it a try. Might not be there for evermore.
It does work in Gimp 2.10 Find it in File -> Create -> Logos(gimpchat.com) -> Glass Effect Text
PostPosted: Tue Jan 01, 2019 5:16 am  (#4)
That is !
Thanks Rich.
Now you may play as you like, level_0.
Happy New Year 2019 !
PostPosted: Tue Jan 01, 2019 6:50 am  (#5)
thank dinasset but I tried it and I'm disappointed because only 2 settings
PostPosted: Tue Jan 01, 2019 6:54 am  (#6)
:tyspin thank you rich2005 for the direct link :bigthup :)
because:
I just have to try ...
:tyspin :tyspin
PostPosted: Tue Jan 01, 2019 6:12 pm  (#7)
I am not sure if this is the same script as you are looking for, but was updated for 2.10 by Paul Sherman. Hopefully it works for you if the others do not.
210_create-new_glass-text.scm [5.31 KiB]
Downloaded 454 times
PostPosted: Wed Jan 02, 2019 3:33 am  (#8)
Thanks Pat625
I will try them today. :)
PostPosted: Wed Jan 02, 2019 5:53 am  (#9)
In preferences, 3 "glass" scripts:
My tests:
1) with Kward1979:
-The outline is blue
-must change the blur and opacity on the layer shadows
2) with Alpha to logo / Glass Effect Alpha, the outline is not very sharp and is a bit distorted
3) I did not find the 3rd script?
PostPosted: Wed Jan 02, 2019 8:25 am  (#10)
I just realized that going through: File / Create / Logo (gimpchat), or Filters / Alpha to logo, it's different;there are more possibilities for settings with File / Create/ Logo (gimpchat)
With File / Create / Logo (gimpchat):
With Filters / Alpha to logo:
so I think the latter is the 3rd that I did not find?
PostPosted: Wed Jan 02, 2019 10:34 am  (#11)
Many logo/text scripts, especially the ones made by GnuTux and Graechan have alpha-to-logo version added so that you can use the effect also for other purposes.
These are easy to mix with each other.
The one updated by Sherman (on left) has different title, menu entry is "Script-Fu/Create New/GlassEffect Text"
And I think it's useless if you have the Glass Effect Text 1.4.
PostPosted: Wed Jan 02, 2019 1:14 pm  (#12)
Nidhogg Image
thank you for your reply :)
Image Image
PostPosted: Thu Jan 03, 2019 6:18 am  (#13)
Using tips for Glass Effect text and tutorial Issabella superbly explained here:
http://gimpchat.com/viewtopic.php?f=23&t=9901
Thank you all who allow me to progress!
but I still have a question:
how to improve the edge of the letters of the word "evasion",irregular and not clear?
PostPosted: Thu Jan 03, 2019 4:26 pm  (#14)
Hi, level_0, I think that the edges may be better if applying a path, but not sure. I hope someone here can help. ;)
Thanks for your comment, too.
PostPosted: Fri Jan 04, 2019 2:10 am  (#15)
Issabella, I had also thought of making a path and painting along a path but I had the laziness to try!
So now I'm going to have to do it ;)
PostPosted: Fri Jan 04, 2019 3:03 am  (#16)
Finally the problem of the crenelage on edge of the letters appears if I choose a depth < 3. So if I make a path along the text, I get the same thing as leaving 3 for the depth .... ;)
PostPosted: Fri Jan 04, 2019 3:14 am  (#17)
May I suggest that in cases like the image you posted following Issa's very nice tut it's better not to use glass text but simply writing your text on a different layer, applying as suggested the selection->to path and stroking the path?
Afterwards you may play with colors, transparency, mode adjustments to obtain a text you like.
PostPosted: Fri Jan 04, 2019 3:26 am  (#18)
Just an example, you surely can create a nicer text.
PostPosted: Fri Jan 04, 2019 3:54 am  (#19)
level_0, do you already have layerfx.py in your plugins folder?
It's essential in my opinion, includes also stroke.
(My menu entry is customized, it's under Layer by default)
PostPosted: Fri Jan 04, 2019 6:42 am  (#20)
dinasset,good idea to test ! :) before I already tested with other colors in the script and here with the green that is better with the background
