It is currently Sun Aug 30, 2026 12:46 pm
 Post subject: Globe View
PostPosted: Fri Jan 04, 2019 3:49 am  (#1)
Because this Issabella's nice tutorial has been re-discovered recently, I re-post here my script (written a long time ago) which implements that tut.
I think you can still use it in 2.10, at least I tried and it works, but my opinion is not fully relevant because on my Samj's 2.10 old scripts run while in other environments they fail, so please give it a try.
DIEGO_Globe-view.7z [2.15 KiB]
Downloaded 395 times
 Post subject: Re: Globe View
PostPosted: Fri Jan 04, 2019 4:39 am  (#2)
It works great! Thanks Dinasset. :yes
PostPosted: Fri Jan 04, 2019 5:09 am  (#3)
Thanks Issabella for testing it, hope someone else will do it, maybe using the standard Gimp release.
PostPosted: Fri Jan 04, 2019 7:47 am  (#4)
Thanks Dinasset
Edit:
why does it appear here in the menu bar and not in the filters menu?
PostPosted: Fri Jan 04, 2019 8:14 am  (#5)
Thanks for testing it, Level_0
PostPosted: Fri Jan 04, 2019 10:21 am  (#6)
Because it was written to. You can change the menu entries of scripts and .py plugins with text editor.
I think notepad is able to save it as .scm, but it's better to use Geany (Linux) or Notepad++ on Windows.
Open the Globe-view.scm and search for "<Image>/DNscripts/...
Then change it to "<Image>/Filters/Map/Globe View of an Image" for example.
Save to .scm format by overwriting the one in your scripts folder.
You can edit while Gimp is running and after saving use Filters/Script-Fu/Refresh Scripts to find it from its new menu location.
Or download the attachment I added. I have it in Filters/Map
DIEGO_Globe-view.scm [5.79 KiB]
Downloaded 303 times
PostPosted: Fri Jan 04, 2019 1:47 pm  (#7)
Nidhogg,I do not know which of the 2 red boxes is Notepad ++
so I'm going to make it easier tonight by taking the file you're proposing ;) (but that would be nice if I learned how to do it for next time ..) :)
PostPosted: Fri Jan 04, 2019 2:29 pm  (#8)
Neither one, go here and download the correct version for your environment (32bits/64bits)
https://notepad-plus-plus.org/download/v7.6.2.html
PostPosted: Fri Jan 04, 2019 3:20 pm  (#9)
Nice filter, works fast.
Thank You
PostPosted: Sat Jan 05, 2019 12:59 am  (#10)
3 attempts in Windows gimp 2.10.8
PostPosted: Sat Jan 05, 2019 1:08 am  (#11)
Tom, Sally, thanks for testing it.
PostPosted: Sat Jan 05, 2019 2:39 am  (#12)
Notepad ++ :bigthup :bigthup
I just tested the addition of "Filters" and it's OK. :)
Thanks Nidhogg
PostPosted: Sat Jan 05, 2019 10:04 pm  (#13)
WoW! All of those images are really fantastic!
I was able to do some tonight.
This was done with Gimp 2.10.8 Samj ver 2. on Win 10, 64 bits.
PostPosted: Sun Jan 06, 2019 12:46 am  (#14)
Well done, Pat.
PostPosted: Wed Jan 23, 2019 4:31 am  (#15)
PostPosted: Tue Nov 10, 2020 4:38 pm  (#16)
Any updates forthcoming, Diego?
PostPosted: Wed Nov 11, 2020 12:51 am  (#17)
Which update are you thinking about, Mahvin?
PostPosted: Wed Nov 11, 2020 1:05 am  (#18)
https://gimplearn.net/viewtopic.php?f=1 ... 358#p33358
Not sure what the problem was with 2.10.6 but I figured you'd be interested in knowing about this...
PostPosted: Wed Nov 11, 2020 1:26 am  (#19)
I tried and it works on Samj's 2.10.23
PostPosted: Wed Nov 11, 2020 2:18 am  (#20)
PS: users having different versions of Gimp 2.10 may try and let know.
