It is currently Sat Aug 29, 2026 8:52 pm
 Post subject: Add Alpha Channel to All Layers
PostPosted: Mon May 09, 2011 9:33 am  (#1)
A request for script writers. Is it possible to write a script to add an alpha channel to all layers that don't have one?
 Post subject: Re: Add Alpha Channel to All Layers
PostPosted: Mon May 09, 2011 9:54 am  (#2)
Yes, I think it would be possible. Not that hard either.
PostPosted: Mon May 09, 2011 10:04 am  (#3)
def py_add_alpha(img, drawable):
  layerlist = img.layers
  for l in layerlist:
     if not l.has_alpha:
        pdb.gimp_layer_add_alpha(l)
just needs register, etc.
PostPosted: Mon May 09, 2011 10:09 am  (#4)
Or if you prefer a script:
all-layers-add-alpha.scm [1.5 KiB]
Downloaded 2230 times
The script will be found in
Layer > All Layers > Add Alpha to All Layers
PostPosted: Mon May 09, 2011 10:10 am  (#5)
ok, here it is
http://www.fileden.com/files/2010/2/7/2 ... d_alpha.py
damn, fastposted. This one is in filters->alpha to all...
PostPosted: Mon May 09, 2011 10:14 am  (#6)
Thank you dd. I don't know how to add a register. Will it show up in GIMP as it stands?
PostPosted: Mon May 09, 2011 10:15 am  (#7)
No, but I made a complete plugin for you, here
PostPosted: Mon May 09, 2011 10:19 am  (#8)
Thanks dd and bkh1914.
Scripts for Python and non-Python users.
How cool is that?! :bigthup
I'll give them both a try.
PostPosted: Mon May 09, 2011 10:36 am  (#9)
Both work perfectly.
Dd, I moved yours to "<Image>/Layer/Alpha to all..."
Thank you both very much!
Didn't even have to do a rain dance. Sun is shining here. :hexer
PostPosted: Sun Jan 24, 2021 12:09 am  (#10)
Had a need for this (about to do a photo collage for Hank Aaron). The python isn't detected but the Script-fu works great and I appreciate it. Still, GIMP is very slow at importing layers and exporting layers (ouch). lol
PostPosted: Sun Jan 24, 2021 5:43 am  (#11)
No need for this script any more Lyle, just change the default settings to what they should've been all along....
