It is currently Wed Aug 26, 2026 1:24 pm
 Post subject: Toggle paths Python plugin
PostPosted: Thu Jan 31, 2019 12:43 pm  (#1)
Recently, I often play with paths.
I needed a tool to switch visibility / chains in a large number of paths - so I wrote a simple plugin in two versions (they do the same - but the version without displaying is probably a bit faster).
I invite You to test.
Switching paths.zip [939 Bytes]
Downloaded 229 times
Switch_paths_noUI.zip [891 Bytes]
Downloaded 216 times
 Post subject: Re: Toggle paths Python plugin
PostPosted: Sat Feb 02, 2019 2:37 am  (#2)
I introduced a cosmetic change in the menu for "Switch_paths_noUI.py" and one more small addition: plugin to delete paths (all visible or invisible - for time saving) in "Remove all paths.py".
Switch_paths_noUI_v2.zip [1 KiB]
Downloaded 207 times
Remowe all paths.zip [668 Bytes]
Downloaded 209 times
PostPosted: Sun Feb 24, 2019 12:38 pm  (#3)
One more small trick.
In the Gimp menu, "Raise Path" and "Lower Path" are in two places.
There are no options: "Raise Path to Top" and "Raise Path to Bottom" .
This can be changed by editing (while maintaining a backup) the vectors-menu.xml file (located in GIMP 2\share\gimp\2.0\ menus).
    <separator />
    <menuitem action="vectors-new" />
    <menuitem action="vectors-raise" />
    <menuitem action="vectors-raise-to-top" />
    <menuitem action="vectors-lower" />
    <menuitem action="vectors-lower-to-bottom" />
    <menuitem action="vectors-duplicate" />
    <menuitem action="vectors-delete" />
    <menuitem action="vectors-merge-visible" />
    <separator />
