It is currently Wed Aug 26, 2026 6:29 pm
 Post subject: Sticker/stickerify plug-in
PostPosted: Sat Feb 09, 2019 2:38 pm  (#1)
requested by Mackenzieh (following Logos by Nick on YT).
https://www.gimplearn.net/viewtopic.php?f=3&t=2079
TinT
 Post subject: Re: Sticker/stickerify plug-in
PostPosted: Tue Feb 12, 2019 5:17 am  (#2)
Thank You - I like all Your plugins.
I was playing with Your new plugins a little bit.
I added in the Color Chips Plug-in - "Circle" (it's simple) - but maybe You can add other shapes (like in Words To Shapes ...)?
pdb.gimp_image_select_ellipse(new_image,CHANNEL_OP_REPLACE,x,y,side,side)
Color Chips Plug-in
https://www.gimplearn.net/viewtopic.php?f=3&t=2069&sid=fd0b36484a395b60a16c047776e8a62f
Run Code on Visible Layers
https://gimplearn.net/viewtopic.php/Run-Code-on-Visible-Layers-Script-for-GIMP?f=3&t=1027
PostPosted: Tue Feb 12, 2019 12:28 pm  (#3)
For each shape you add you have to properly calculate the size of shape so that the area of shape has approx. same number of pixels as number of pixels found on image.
That's just too complex for me hehehe.
TinT
