It is currently Wed Aug 26, 2026 1:25 pm
 Post subject: gimp-plugin-export-layers has been Updated
PostPosted: Mon Feb 18, 2019 1:33 pm  (#1)
Hi everyone, just letting people know here that the "gimp-plugin-export-layers" from khalim19 has been updated for Gimp 2.10.
Go to https://github.com/khalim19/gimp-plugin ... s/releases
 Post subject: Re: gimp-plugin-export-layers has been Updated
PostPosted: Mon Feb 18, 2019 6:13 pm  (#2)
Thanks for this Pocholo. I may have to use this very soon. I was wondering how to export multiple alpha PNGs into a video editor.
This also works on Gimp 2.8.
PostPosted: Mon Feb 18, 2019 6:59 pm  (#3)
There is also ofn-export-layers:)
PostPosted: Tue Feb 19, 2019 5:13 pm  (#4)
A comparison would be interesting :)
PostPosted: Fri Feb 22, 2019 5:13 pm  (#5)
Did a comparison.
Using Gimp 2.8 the khalim19 plugin didn't show-up in any menu entry I could see.
The ofnuts plugin exported multiple alpha PNGs and was easy to use.
PostPosted: Fri Feb 22, 2019 6:26 pm  (#6)
Doesn't show up in Gimp 2.10.8 either. Offnuts plugin does work however....
PostPosted: Sat Feb 23, 2019 12:34 am  (#7)
@Pocholo
Thanks for the update. Works fine with Gimp 2.10.8, Windows 10 Home x64
