It is currently Tue Sep 01, 2026 2:51 pm
 Post subject: Postal Stamp Plug-in
PostPosted: Fri Mar 15, 2019 7:15 pm  (#1)
Modeled after real stamp found on the net.
With perfectly aligned holes (perforation). I saw a script that was called Stampify but it didn't seem to align care where the holes ended up so it bothered me a little. Also this plug-in will add a simple rectangular border (average color of image unless colorized).
From this:
To these:
Plug-in can be found here --> Postal Stamp Plug-in
TinT
 Post subject: Re: Postal Stamp Plug-in
PostPosted: Fri Mar 15, 2019 8:58 pm  (#2)
Cooooool, thanks. :clap
PostPosted: Fri Mar 15, 2019 9:01 pm  (#3)
What did you apply to your stamps.
Looks good.
TinT
PostPosted: Fri Mar 15, 2019 9:16 pm  (#4)
It's "old-photo-bakumatu.scm" found from japanese Gimp site and translated.
First I tried "mholdstamp.scm" from here, which would be perfect but I couldn't get a good look.
http://kikidide.yuki-mura.net/GIMP/gimpsonota.htm
PostPosted: Sat Mar 16, 2019 6:27 pm  (#5)
Cool!
I also fixed and attached the oldstamp.scm so it will now work in GIMP-2.10.8 :)
in installs in the scripts folder and you will find it under the menu Script-Fu>Oldstamp
2028_mholdstamp.scm [2.31 KiB]
Downloaded 180 times
PostPosted: Sat Mar 16, 2019 8:18 pm  (#6)
Tried downloading 2028_mholdstamp.scm.
Had one error FG-IMAGE-FILL changed it to FILL-FOREGROUND
2028_mholdstamp.scm [2.32 KiB]
Downloaded 204 times
TinT
PostPosted: Sun Mar 17, 2019 4:57 pm  (#7)
2028_mholdstamp.scm
Working fine on Partha's portable 2.10.8.
The effect is amazing! I noticed it creates a small glitch on top of the image, but it's not much noticeable.
PostPosted: Tue Mar 19, 2019 6:30 am  (#8)
Thanks a bunch for this awesome plug in Tim :)
PostPosted: Tue Mar 19, 2019 6:31 am  (#9)
Thanks for sharing Nidhogg, this Japanese effect is perfect for this plug in :)
PostPosted: Tue Mar 19, 2019 1:02 pm  (#10)
Where could I get the first script? (old-photo-bakumatu.scm)
PostPosted: Tue Mar 19, 2019 3:47 pm  (#11)
Attached. It's in Filters/Artistic.
old-photo-bakumatu.scm [5.84 KiB]
Downloaded 142 times
PostPosted: Tue Mar 19, 2019 4:09 pm  (#12)
the original tutorial for old stamp can be found via the internet archive:
https://web.archive.org/web/20060703175 ... stamp.html
PostPosted: Wed Mar 20, 2019 7:20 am  (#13)
Thank you! :bigthup
PostPosted: Wed Mar 20, 2019 10:54 am  (#14)
:tyspin
