It is currently Tue Sep 01, 2026 11:27 am
 Post subject: GC-Lense-Flare not working in 2.10 Help!!! (Solved)
PostPosted: Sat Mar 16, 2019 8:04 pm  (#1)
Does anybody know Graechan? He created a script "GC-Lense-Flare" and i have not see him here. Is he part of Gimpchat Coders?
I downloaded the script and when I try to use it, gave me this error:
"Unbound Variable: Interpolation Lanczos"
Can anybody guide me or help me how to fix it
viewtopic.php?f=9&t=11635&hilit=gc+flare
 Post subject: Re: GC-Lense-Flare not working in 2.10 Help!!!
PostPosted: Sat Mar 16, 2019 8:13 pm  (#2)
Quite a bit needs to be fixed in the script in order for it to run in GIMP 2.10. Mainly the mode parameters. I will see what i can do. :bigthup
PostPosted: Sat Mar 16, 2019 8:34 pm  (#3)
Thanks a lot Rod, I I'll appreciated. Wow that was a fast answer :clap
PostPosted: Sat Mar 16, 2019 8:43 pm  (#4)
There is no longer that parameter available so i changed it to
INTERPOLATION-LOHALO
Everything fixed in the script except for this one error. Same one i get for his fill brush script.
Error while executing script-fu-gc-lens-flare:
Error: ( : 1) atom->string: needs 1 argument(s)
I will keep working on it.
:ninja
PostPosted: Sat Mar 16, 2019 8:48 pm  (#5)
Seems to work ok if you do not select to display path information on the widget itself.
I attached the script. Ill keep working on it. I will attach it here when i get it fixed.
GC Lens-Flare.scm [16.67 KiB]
Downloaded 156 times
You will find it under Filters>Light and Shadow>GC Lens-Flare
PostPosted: Sat Mar 16, 2019 9:02 pm  (#6)
Strange.
For some reason this parameter
plug-in-gauss-rle2
according to the procedure browser allows for a max of 500. BUT it will only allow for 250. Or it errors out.
Well i attached the newer version here. REMEMBER you still cannot display path info or it will also error out. Still trying to see whats up with that.
Downloaded 194 times
PostPosted: Sat Mar 16, 2019 9:09 pm  (#7)
Results from these settings on pretty big text.
PostPosted: Sat Mar 16, 2019 9:12 pm  (#8)
Remember to use the script you need to create a 3 point path (3 anchors) before you run the filter.
PostPosted: Sat Mar 16, 2019 9:26 pm  (#9)
Another useful piece of information.
If you first copy the 3 point path in the paths dialog (right click copy path), you can then run the filter on the first path and then paste the same path Edit>Paste and run the script again in the same place for a brighter effect.
PostPosted: Sat Mar 16, 2019 9:26 pm  (#10)
Thank a lot Rod. I appreciate that you took your time to fix this script and help me. Man, I thank you again! :tyspin
PostPosted: Sat Mar 16, 2019 9:28 pm  (#11)
No problem. Just remember to download the second attachment for the taper correction. :bigthup
PostPosted: Sat Mar 16, 2019 9:45 pm  (#12)
It's working 100 percent, now. :hi5
PostPosted: Sun Mar 17, 2019 1:41 am  (#13)
Awesome! :bigthup
 Post subject: Re: GC-Lense-Flare not working in 2.10 Help!!! (Solved)
PostPosted: Sun Mar 17, 2019 2:15 am  (#14)
I noticed an error upon using a selection instead of a path in the script so....
This version allows you to use a selection as well as a path. :)
GC Lens-Flare.scm [16.69 KiB]
Downloaded 160 times
PostPosted: Sun Mar 17, 2019 2:17 am  (#15)
PostPosted: Sun Mar 17, 2019 8:54 am  (#16)
GC Lens-Flare.scm
Neat! I'm going to try it :coolthup
