It is currently Tue Sep 01, 2026 12:37 pm
 Post subject: Invoke GEGL to batch process images
PostPosted: Mon Mar 18, 2019 1:34 pm  (#1)
Hello everyone!
I'm fairly new to GIMP and Python scriptinging general. I'm trying to make a script that does the following:
-Loads an image in a source folder
-Applies the Mono-Mixer with fixed parameters (All maxed out)
-Saves the modified version on separate folder with a name modifier ("_result", for example)
-Closes the image
-Loops for the next image in source folder until it cicled through all of them
Problem is: I can't find the command for the Mono-mixer since it's not a native GIMP procedure. Is there a way to write this so that it can batch apply the mono-mixer?
Thanks for the help!
Here are my specs:
OS: Windows 7 64-bits
GIMP version: 2.10.6
Relevant Plugins: BIMP
 Post subject: Re: Invoke GEGL to batch process images
PostPosted: Mon Mar 18, 2019 4:22 pm  (#2)
AFAIK there is no API for the GEGL things. I even assume that the script-fu/python-fu API in 2.10 still uses the old non-GEGL code.
For simple things like this you can use ImageMagick's convert utility in a shell script. The mono mixer all maxed out is nothing more than a desaturation followed by a boost of the lights.
