It is currently Tue Nov 24, 2026 6:25 am
Post new topic Reply to topic  [ 56 posts ]  Go to page 1, 2, 3  Next
 Post subject: BorderBox - create border step by step
PostPosted: Thu Mar 21, 2019 2:02 pm  (#1)
This simple plugin was supposed to be part of:
sample_color_border.py http://gimpchat.com/viewtopic.php?f=9&t=17268&sid=99c6bb5018ea59cbe9365672388fa895
Due to some users' problems related to using it - that project was terminated until a solution was found (now I suspect that Windows 10 in some settings blocks the script-fu background call - but the reasons may be different).
There is a piece of code left, so I'm sharing it with You.
Basic assumptions:
- in menu GIMP: Filters/Decor/Create border step by step...
- based on the set colors FG and BG,
- repeating to add another frame (so a free margin should be used at the end),
- the frame is created using paths that can be used to obtain additional effects,
- additional effects attached:
CUBISM, EMBOSS, GIMPRESSIONIST, MOSAIC, PIXELIZE, RIPPLE, SPREAD, VIDEO
they work interactively (calling the plug with a preview of changing selected parameters),
- since version 2.10 some of the plugins used have been replaced by GEGL which until now can not be done from the level of the plugin,
- the missing plugins attached come from GIMP 2.8.22 and work well in GIMP 2.10 - but I only have a 32 bit version
[Missing plugins_Win_32 bit.zip it contains: cubism.exe, mosaic.exe, noise-spread.exe, pixelize.exe, video.exe]
Create border step by step V 0.1.zip [1.99 KiB]
Downloaded 374 times
 Post subject: Re: Create border step by step.py
PostPosted: Thu Mar 21, 2019 2:04 pm  (#2)
Missing plugins:
Edit 29-03-2019: New plugins attachment in post # 15
PostPosted: Fri Mar 22, 2019 9:54 pm  (#3)
MareroQ, did you want the 64 bit plug-ins? My computer is 64 bit Windows 10. I still have Gimp 2.8.22 64 bit if you need something from it?
Edit: I installed the Step by Step program and the "Missing ones" in the same plug in folder. However when I go to use the Step by Step, it cannot find those files and I get errors. Am I to install the missing files in another place? Please advise. Sorry to be such a problem.
PostPosted: Sat Mar 23, 2019 12:45 am  (#4)
Hi Pat.
If You can, I have a request for a small test:
- copy mosaic.exe from Gimp 2.8 64bit to 2.10 64bit (yes -the Preferences / plug-ins folder is the right choice),
- start Gimp 2.10 and plugin create border for Additional effect: MOSAIC.
- start create border for Additional effect: GIMPRESSIONIST
The question is - does it work?
If not, it only confirms my hypothesis that it is Windows10 (in the settings) that blocks the execution (of the program by another program :ninja ).
If so - then I am asking for a plugin package with Gimp 2.8 Win 64bit (for anyone interested in using the plugin for Gimp 2.10 64bit :bump ):
apply-canvas.exe
cubism.exe
mosaic.exe
noise-spread.exe
pixelize.exe
video.exe
Thank You in advance and I apologize for the inconvenience. :oops:
PostPosted: Sat Mar 23, 2019 3:36 pm  (#5)
MareroQ, thank you for answering me. I took the Gimp 2.8 64 bit plugins and tried them in your Step by Step program and all worked well except Ripple. I know you did not asked for it but I checked all of them and nothing happened with Ripple. I placed a 2.8 Ripple 64 bit in there With the others, the other files were called and worked. Ripple was called, but did not work properly. UPdate: For some reason, Ripple is now working with the 2.8 plug-in. Do not know what is different. I think all are now working! I have included Ripple (and Emboss just in case you needed it).
Let me know if you need any more files from Gimp 2.8.22. Thank you again for all your work. You are probably tired of working on this by now!
I have included some images for you to check to see if worked properly.
PostPosted: Sat Mar 23, 2019 3:39 pm  (#6)
Continuing . . . .
PostPosted: Sat Mar 23, 2019 4:20 pm  (#7)
continuing . . . .
and Ripple which also works! It did not seem to work for me when I first put in the 64 bit plug in, but afterwards I have tried several times and appears to work. I understand that you only get the effect on the sides when horizontal is chosen.
64 bit Gimp files.zip [229.69 KiB]
Downloaded 333 times
PostPosted: Sat Mar 23, 2019 5:39 pm  (#8)
Thank You for the tests, examples and the missing files in GIMP 2.10 64bit from 2.8. :hi5
I am not bored yet so this is the next version:
Ver. 0.2
- add APPLY CANVAS for Additional effect,
- add Stroke box with active brush: Inside/Outside/Both frame box, Foreground/Background brush color.
Create border step by step V 0.2.zip [2.21 KiB]
Downloaded 326 times
PostPosted: Sat Mar 23, 2019 10:05 pm  (#9)
MareroQ, I really love this one! Need to practice some as I do not know why the second one is the way it is. I like it though. Thank you for another great toy!
PostPosted: Tue Mar 26, 2019 12:03 pm  (#10)
Ver. 0.3
- add select to Gradient type: "LINEAR", "SHAPEBURST-ANGULAR", "SHAPEBURST-SPHERICAL", "SHAPEBURST-DIMPLED";
- add select to Stroke color brush: "Black", "White";
- add select to Additional effect: "Felimage(only 32bit)", "Newsprint", "Voronoi", "Pattern fill"(in mode: "DIFFERENCE", "SUBTRACT", "DARKEN-ONLY", "HARDLIGHT", "GRAIN-MERGE").
Create border step by step V 0.3.zip [3.04 KiB]
Downloaded 323 times
PostPosted: Tue Mar 26, 2019 1:29 pm  (#11)
WOW! Can't wait to try these! You have been very busy.
PostPosted: Tue Mar 26, 2019 10:28 pm  (#12)
Thank you very much for these additions to the plug-in. I really love this script!!
MQ.Create Border.Shapeburst Angular.Apply Canvas.Hardlight.Repeat.jpg [ 422.17 KiB | Viewed 8643 times ]
MQ.Create Border.Shapeburst Dimpled.Emboss.Difference.jpg [ 171.27 KiB | Viewed 8643 times ]
MQ.Create Border.Shapeburst spherical.Gimpressionist.Hardlight.jpg [ 276.85 KiB | Viewed 8643 times ]
PostPosted: Wed Mar 27, 2019 2:07 am  (#13)
Thank you so much for your nice border script. It makes very nice results in frames. I'll test it soon.
Nice job Pat.
PostPosted: Wed Mar 27, 2019 7:15 am  (#14)
Nice plug-in MareroQ! Can't wait to try it out. :)
PostPosted: Fri Mar 29, 2019 9:10 am  (#15)
Thank You all for Your interest.
Ver. 0.4.
- add "Additional effect": ENGRAVE, NOISE GENERATOR, REFLEXION BORDER.
- now: select layer-mode for all effects,
Some additional information:
Noise-generator
Noise-generator-0.2.5_64bits_Win
https://samjcreations.blogspot.com/2018/05/filtres-anciens-pour-gimp-210-64-bits_25.html
Voronoi-2.2_64bits_Win
https://samjcreations.blogspot.com/2018/05/filtres-anciens-pour-gimp-210-64-bits.html
Felimage Noise Plugin v 0.1.1 for the GIMP: http://fimg-gmplugins.sourceforge.net/
in menu GIMP: Filters/Render/Felimage/Noise...
In my compilation (in attachment)
in menu: Filters/Render/Pattern/Felimage Noise...
The zip of "Add plugins for GIMP 2.10_Win_32bit-from older versions" includes:
- apply-canvas.exe,
- cubism.exe,
- engrave.exe,
- felimage-noise.exe + preset,
- mosaic.exe,
- noise-generator.exe,
- noise-spread.exe,
- pixelize.exe,
- video.exe,
- voronoi.exe.
Add plugins for GIMP 2.10_Win_32bit-from older versions.zip [297.2 KiB]
Downloaded 337 times
PostPosted: Fri Mar 29, 2019 2:18 pm  (#16)
Nice plugin: #4 I do not often use frames but for those linux users there is hope
felimage:
and the old photocomix noise-generator:
however never-ever been able to compile the voronoi plugin
PostPosted: Fri Mar 29, 2019 5:36 pm  (#17)
Great job MareroQ. Very impressive work. Thanks also for supplying the plugins.
PostPosted: Sat Mar 30, 2019 4:46 am  (#18)
Thank Rich2005 and Wirra for positive feedback.
Ver. 0.5.
- error removed (wrong layer selection to apply effect - in ver.0.4)
- add "Additional effect": KALEJDOSCOPE, PERSPECTIVE BORDER
- now: select "Corner type": SLANTED, RECTANGULAR T-B, RECTANGULAR R-L.
KALEJDOSCOPE
kaleidoscope-0.10-3_32bits-64bits-Win
https://samjcreations.blogspot.com/2018/05/filtres-anciens-pour-gimp-210-windows.html
PERSPECTIVE BORDER
Based on the plugin "Pespective Border Plug-in.py" by Tin Tran.
https://gimplearn.net/viewtopic.php?f=3&t=2142
Create border step by step V 0.5.zip [4.97 KiB]
Downloaded 282 times
PostPosted: Sun Mar 31, 2019 8:48 pm  (#19)
MareroQ, thank you so much for such a nice border effect plug-in. Love it!
PostPosted: Mon Apr 01, 2019 1:47 am  (#20)
Thanks Pat, I'm glad You like it.
Ver. 0.6
Only a small change:
In an additional effect "PATTERN FILL:
- two directions will be filled,
- resignation from pattern desaturation for the possibility of using Bump Map.
bump-map_win-32bit.zip [22.52 KiB]
Downloaded 257 times
Create border step by step V 0.6.zip [5.17 KiB]
Downloaded 262 times
