It is currently Tue Sep 01, 2026 5:36 pm
 Post subject: Movie 300 script error (Solved)
PostPosted: Fri Mar 22, 2019 1:03 pm  (#1)
OS Windows 10
Gimp 2.10.6
Can any of the Code Guru fix this script, I really love this filter. Thank you in advanced!
Error while executing Elsamuko-movie-300;
Error: ( : 1) eval: unbound variable: MIDTONES
and probably this one too
Error: ( : 1) eval: unbound variable: HIGHLIGHTS
elsamuko-movie-300.scm [9.31 KiB]
Downloaded 121 times
 Post subject: Re: Movie 300 script error
PostPosted: Fri Mar 22, 2019 2:04 pm  (#2)
Fixed the script, sort of.
The problem is that it used Scatter HSV which isn't included in 2.10
I changed it to use HSV noise, but am not sure if the outcome looks same than on 2.8
Don't have 2.8 anymore and never used this filter so I can't tell.
This is how it looks when used on Lenna reference image. Attached the script if you want to try out.
elsamuko-movie-300.scm [9.49 KiB]
Downloaded 129 times
PostPosted: Fri Mar 22, 2019 2:39 pm  (#3)
It keeps giving the same error I mention above
PostPosted: Fri Mar 22, 2019 2:55 pm  (#4)
Worked okay on Linux.
How about this one?
Remember to run Filters/Script-Fu/Refresh Scripts after replacing the old.
elsamuko-movie-300.scm [9.51 KiB]
Downloaded 123 times
PostPosted: Fri Mar 22, 2019 3:18 pm  (#5)
Thanks it fixed the prior Error but now it shows this error:
Error: ( : 1) eval: unbound variable: ALL-HUES
PostPosted: Fri Mar 22, 2019 3:24 pm  (#6)
Fixed it, and desaturate-luminance. Hope it works on windows now.
elsamuko-movie-300.scm [9.52 KiB]
Downloaded 134 times
PostPosted: Fri Mar 22, 2019 4:06 pm  (#7)
It was giving me another Error: "DESATURATE-LUMINOSITY". But I know that GIMP 2.10 does not have "LUMINOSITY" in Desatutrate anymore, it's "LUMINANCE". So I changed "LUMINOSITY" for "LUMINANCE" and now it worked perfectly. Thank you Nidhogg, for your time and work, you did the harder part. :tyspin
 Post subject: Re: Movie 300 script error (Solved)
PostPosted: Fri Mar 22, 2019 4:33 pm  (#8)
Yeah, I replaced luminosity with luminance but was so excited that I forgot to replace them all.
You're welcome, glad it works.
