It is currently Tue Sep 01, 2026 8:11 pm
 Post subject: Seamless Cut Plug-in
PostPosted: Thu Mar 28, 2019 10:00 pm  (#1)
This plug-in will help you extract a seamless tile from an image that isn't seamless (but contains the seamless tile).
I don't know if there is such plug-in out there that behaves like this or not.
But let's say you got an image like this (which isn't seamless but you know it contains a seamless pattern).
You can get it to this by using the plug-in (vertical cut) (after making a vertical selection of where you think the seamless should be within)
Then you can get it to this using plug-in (horizontal cut) (after making a horizontal selection of where you think the seamless should be within) \on result above to get it to be a completely seamless tile.
More details about plug-in --> https://gimplearn.net/viewtopic.php?p=24952#p24952
TinT
 Post subject: Re: Seamless Cut Plug-in
PostPosted: Fri Mar 29, 2019 11:55 pm  (#2)
Really cool, Tran (just watched the video). :)
PostPosted: Sat Mar 30, 2019 5:01 am  (#3)
Hi Tin.
A very useful plugin.
I will apply it to the miniaturization of all my patterns.
Thank you very much.
PostPosted: Sat Mar 30, 2019 11:01 am  (#4)
Awesome Tran. Big thumbs up!
PostPosted: Sat Mar 30, 2019 3:18 pm  (#5)
Thanks, glad you guys like it.
TinT
