It is currently Mon Aug 31, 2026 5:35 am
 Post subject: Custom Font Tools Release 6 for Gimp 2.10
PostPosted: Thu Apr 04, 2019 5:56 am  (#1)
It appears that I have not added updates to my Custom Font Tools since Release 3 - now at Release 6.
Custom Font Tools R6.zip [86.45 KiB]
Downloaded 368 times
There are now three new tools since Release 3. This is a zipped folder with all the tools included for the sake of completedness.
Download, unzip and update the files and add them, or just the ones you need, to your plug-ins folder.
Tool List:
FontSlab: v.0.09
Distortion Pack 1: v.0.01
Distortion Pack 2: v.0.01
Effects Only: v.0.006
Layer Utils: v.1.14
Layers From Fonts: v.0.05
Outlines Only: v.0.01
Artistic Pack: v.0.02
Noise Pack: v.0.01
Paths to Layers: v.0.03
Character Paths: v.0.04
Face Maker: v. 0.01
Please refer to individual plug-ins help by searching GimpLearn.net
Brief Tool Descriptions for new users:
Custom Font Character Paths - strokes characters in a variety of ways by creating paths from selections
Custom Font Layers from Fonts - converts a font into a series of plain character layers that can be worked on in Gimp
Custom Font Paths to Layers - paints a series of character shaped skeleton paths with the paintbrush to create character layers
Custom Font Layer Utilities - set of utilities for working with character layers to speed up the process of creating custom fonts
Custom Font Outlines Only - for adding various types of outlines to character layers or creating outline only characters
Custom Font Effects Only - provides a quick way of applying some effects to all character layers
Custom Fonts Face Maker - paints new font faces onto custom fonts by copying from visible layer/layers
Custom Font Artistic Pack - provides a quick way of applying some of the Artistic filters to all character layers
Custom Font Distortion Packs - provides a quick way of applying some of the Distortion filters to all character layers
Custom Font Noise Effects Only - provides a quick way of applying some of the Noise filters to all character layer
FontSlab - paints given text along a user path with the selected custom font
 Post subject: Re: Custom Font Tools Release 6 for Gimp 2.10
PostPosted: Fri Apr 05, 2019 12:36 pm  (#2)
Thanks Skinnyhouse! :)
PostPosted: Sat Apr 06, 2019 12:28 pm  (#3)
PostPosted: Sat Apr 06, 2019 4:18 pm  (#4)
Thank you Skinnyhouse. It is so convenient to have all the font tools together!
