It is currently Thu Aug 27, 2026 9:23 pm
 Post subject: File/Create menu under Windows 10
PostPosted: Sun Apr 14, 2019 6:48 am  (#1)
Hi,
I'm a newbee, so my question.
Under Gimp 2.8.22 the file/create menu had 9 submenu's.
Under Gimp 2.10 only the submenu's 1 - 4 (from clipboard, from webpage, scanner/camera, screenshot) are visible and the submenu's 5- 9 ( buttons, logos, new brush from text, patterns, web page themes) aren't visible.
How can I solve this?
hanks
 Post subject: Re: File/Create menu under Windows 10
PostPosted: Sun Apr 14, 2019 7:31 am  (#2)
You can solve it at least partially by installing some (scripts, patterns, brushes) of the gimp-data-extras, which were not included in 2.10
The one you want to download is the latest: 11-Jun-2018 14:51 4.3M
gimp-data-extras-2.0.4.tar.bz2
https://download.gimp.org/pub/gimp/extras/
I'm using Linux and scanning via sane.
The gradients entry I had in 2.8 included only custom gradients AFAIK.
Buttons had 2: Simple button and beveled button.
Other entries: Brush from text, web page themes. No idea how to get these into 2.10, never used them.
PostPosted: Sun Apr 14, 2019 7:58 am  (#3)
@Nidhogg
Brush from text is a python plugin, not included in that data-extras package.
Makes an animated brush. Same as you, never used it much. Can be used with a dynamic for an effect.
Attached for anyone interested. The usual, unzip, put in your Gimp profile plug-ins folder. Find in File -> Create.
text-brush.py.zip [1.61 KiB]
Downloaded 109 times
