It is currently Tue Nov 24, 2026 12:42 pm
 Post subject: Dinasset's Stained Glass Filter for G'MIC QT
PostPosted: Fri Apr 19, 2019 7:54 pm  (#1)
I understand that GimpScripts is indefinitely unavailable.
Does anyone have a link to the QT version of Dinasset's Mosiac Stained Glass filter?
Thanks in advance.
 Post subject: Re: Dinasset's Stained Glass Filter for G'MIC QT
PostPosted: Fri Apr 19, 2019 8:49 pm  (#2)
Thanks in advance.
I could only find this:
DIEGO_Mosaic_Stained_Glass.zip [8.01 KiB]
Downloaded 397 times
PostPosted: Sat Apr 20, 2019 12:15 am  (#3)
This is the QT version.
DIEGO_MOSAIC_Mosaic_Stained_Glass_QT210.7z [6.74 KiB]
Downloaded 414 times
This is the "non standard" pattern it uses..
PostPosted: Sat Apr 20, 2019 1:58 pm  (#4)
Thanks in advance.
I've tried both sets of filters and gimp 2.10.10 just isn't reading them but on the upside, I still have Diego's other filters like impasto look, enhanceskin, colourcolour, Lines look, and draw random drops. I have them in my plugins folder in case you're wondering.
PostPosted: Sat Apr 20, 2019 8:19 pm  (#5)
Dear Friends in the Distance, I'm using GIMP 2.10.10 on Windows 10. I've often had issues running many of Dinasset's Python scripts. I _believe_ but I certainly don't know for sure, that the problem might be that the Python initializing string:
#!/usr/bin/env python
does not appear as the first line in the script, but only after an explanatory comment block above the main script.
In both of the above examples, neither showed up in the menus until I cut the initializing string and pasted it at the top of the script file. Both versions then showed up in the menus and the QT210 version worked fine. [I also downloaded the DopeCrystals04seamless.jpg and put it in the patterns folder.] For whatever reason, the first version [in Wallace's post] gives the following error: "File "C:\Program Files\GIMP 2\- TRIAGE\DIEGO_Mosaic_Stained_Glass.py", line 567, in Mosaic_Stained_Glass
pdb.plug_in_gmic(newImage, Preprocessed_Layer, 1, # 1=input only active layer
error: procedure not found"." ["TRIAGE" is my try-it-and-see-if-it-works folder for new scripts.]
I don't know whether my experience with the "#!/usr/bin/env python" line has been the result of a problem with GIMP or scripting or Python or Windows 10 or something else. [A deep echoing voice in my head says, "No, Neurolurker, it's only a problem for you ... "] From the other users in the many previous messages about Dinasset's fantastic scripts, it was very clear that the plugins worked for them without issues, and so far as I recall, no other user mentioned it.
PostPosted: Sun Apr 21, 2019 12:37 am  (#6)
The original version posted by Wallace can't work, because it makes use of the old G'MIC interface.
If the QT version doesn't work, try neurolurkes's suggestion or try the attached file, from which I removed the initial comments.
DIEGO_MOSAIC_Mosaic_Stained_Glass_QT210.7z [5.42 KiB]
Downloaded 571 times
Other people had the same problem (not me and many other I know).
Happy Easter.
PostPosted: Sun Apr 21, 2019 12:40 am  (#7)
Happy Easter.
Happy Easter to you Diego. I will try this version again.
PostPosted: Mon Apr 22, 2019 7:16 am  (#8)
Exactly what i had to do to get Bytes and Pixels filters to work as well.
Word Art
Vector Path
Animated Brush
Spirograph
Glossy Web Button
Simple Button
All now work after adding the Python initializing string.
PostPosted: Mon Apr 22, 2019 3:28 pm  (#9)
Dinasset, your Stained Glass Filter shoots out an error for me in Gimp 2.10.10: RuntimeError: maximum recursion depth exceeded while calling a Python object
  File "/tmp/tmp.8NQFRpbp7C/gimp/2.0/python/gimpfu.py", line 740, in response
  File "/tmp/tmp.8NQFRpbp7C/gimp/2.0/python/gimpfu.py", line 361, in run_script
  File "/home/racer/.config/GIMP-AppImage/2.10/plug-ins/DIEGO_MOSAIC_Mosaic_Stained_Glass_QT210.py", line 73, in Mosaic_Stained_Glass_QT210
    info_msg ("info: I am running "+systemrunning)
  File "/home/racer/.config/GIMP-AppImage/2.10/plug-ins/DIEGO_MOSAIC_Mosaic_Stained_Glass_QT210.py", line 22, in info_msg
    info_msg ("INFO: "+msg)
  File "/home/racer/.config/GIMP-AppImage/2.10/plug-ins/DIEGO_MOSAIC_Mosaic_Stained_Glass_QT210.py", line 20, in info_msg
    currenth = pdb.gimp_message_get_handler()
PostPosted: Tue Apr 23, 2019 12:07 am  (#10)
Sorry, you're right.
You - and all users not running Windows - please replace it with the attached amended version:
Downloaded 475 times
PostPosted: Tue Apr 23, 2019 3:41 am  (#11)
OK, it works now thanks.
PostPosted: Tue Apr 23, 2019 4:28 am  (#12)
Thanks for double-checking.
Should some Windows user encounter the same problem, please download the amended version of post # 10.
PostPosted: Wed Nov 27, 2024 10:21 am  (#13)
Hi all,
This post may be dead, but I was trying to use your plugin. It sadly runs into an issue:
File "R:\GIMP 2\lib\gimp\2.0\python/gimpfu.py", line 741, in response
File "R:\GIMP 2\lib\gimp\2.0\python/gimpfu.py", line 362, in run_script
File "C:\Users\user\AppData\Roaming\GIMP\2.10\plug-ins\DIEGO_MOSAIC_Mosaic_Stained_Glass_QT210.py", line 455, in Mosaic_Stained_Glass_QT210
pdb.gimp_context_set_gradient ("FG to BG (Hardedge)")
RuntimeError: A(z) „FG to BG (Hardedge)” színátmenet nem található
Something with Hardedge. I have used the amended version which was posted here. Can anyone assist?
PostPosted: Wed Nov 27, 2024 11:22 am  (#14)
( Gimp.2.10.38)
Could it be that you don't have the pattern? If you place that in the pattern folder, it works
DIEGO_MOSAIC_Mosaic_Stained_Glass_QT210.zip [293.83 KiB]
Downloaded 80 times
PostPosted: Wed Nov 27, 2024 12:30 pm  (#15)
Does it work with GIMP in English?
PostPosted: Wed Nov 27, 2024 12:38 pm  (#16)
quietreader he asked a very good question
viewtopic.php?f=9&t=10525&p=241201&hilit=Hardedge#p241201
PostPosted: Wed Nov 27, 2024 2:56 pm  (#17)
The culprit is this
"FG to BG (Hardedge)" [Forground to Background]
In languages other than English the wordings and their abbreviation might be different and the script thus does not know what to do. Also "Hardedge" might be called differently in other languages.
Therefore switching to English language might solve the problem.
PostPosted: Wed Nov 27, 2024 3:00 pm  (#18)
I have been trying real hard to switch to english, i figured it out. Only that I don't know how to change to ENG in GIMP
Edit: I did it.
Picture looks horrifying :D its all red and yellow dotted. maybe I did something wrong?
PostPosted: Thu Nov 28, 2024 2:51 am  (#19)
I am ppy to see you Dinasset acting in the forum. :hi5
I did a try with this wonderful filter. :paint
Thanks Dinasset.
PostPosted: Thu Nov 28, 2024 7:38 am  (#20)
Nice to see you again dinasset! :)
This is a very nice filter. I did get an error running it in Windows at first, but i removed the Alpha Channel and it worked great.
