It is currently Thu Aug 27, 2026 9:21 pm
 Post subject: Erase Rows.scm with a small modification
PostPosted: Sat Jun 01, 2019 6:26 am  (#1)
It annoys me. :gaah
Please read that:
Hidden Filters
https://www.gimp-forum.net/Thread-Hidden-Filters
Many thanks Rich2005! :hi5
Since I opened the file to unblock the registration in the menu, I added some typical options...
Add option:
- Rows & Columns,
- size in pixels: "Erase","Gap interval",
- fill: FOREGROUND, WHITE, PATTERN,
- rename in menu-register (and pdb) to: Filters/Distorts/Erase(fill) Rows/Columns by size...
erase-rows-or-columns-by-size.zip [1.67 KiB]
Downloaded 198 times
 Post subject: Re: Erase Rows.scm with a small modification
PostPosted: Sat Jun 01, 2019 7:25 am  (#2)
Hi Gimp Users
I like the effect.
Thanks
Doron 4X5DF
PostPosted: Sat Jun 01, 2019 3:18 pm  (#3)
Thanks MareroQ for an excellent upgrade
PostPosted: Sun Jun 02, 2019 11:16 pm  (#4)
I agree with Steve, an excellent upgrade.
PostPosted: Mon Jun 03, 2019 1:45 am  (#5)
I've used this filter often in 2.8,
to help create various line effect for wallpaper images.
I haven't needed to use it in 2.10,
but being that I do us it.
I know,
that I would have been going nuts looking for it.
Thanks MareroQ,
for adding those useful functions and for the heads up.
PostPosted: Mon Jun 03, 2019 7:03 am  (#6)
Thank you All for Your interest and kind words.
All applause for the author of the script written in 1997 by Federico Mena Quintero.
One more small change (logical):
After adding the size in pixels, the Even Odd entry is only true for 1 px - and it can be confusing so be better to replace it with:
Start with erasing/fill or interval.
erase-rows-or-columns_by-size.zip [1.67 KiB]
Downloaded 187 times
PostPosted: Mon Jun 03, 2019 5:19 pm  (#7)
This is great for help making fences or bars...
PostPosted: Tue Jun 04, 2019 4:13 am  (#8)
@Hi Racer-X
Nicely done.
I wondered how you did it - and I think that new options may be useful:
- Simple border,
- if Erase: add alpha channel,
- add Separate layer (work on copy layer)?
I'm sorry but I also changed the location in the Gimpa menu (but anyone can set it as he wants for his own convenience)
Now: Filters -> Decor -> Erase/Fill Rows/Columns...
ps. In general - I do not like script-fu (I do not understand much yet) and definitely prefer leraning Python.
erase-rows-or-columns_by_size.zip [2.07 KiB]
Downloaded 154 times
PostPosted: Tue Jun 04, 2019 6:59 am  (#9)
I ran your script twice on an image. 1st for rows, then again for columns. I used different settings, then used erase. I added a white layer above the image. I then applied "Alpha to Select" on the image layer, then switched to the white layer and hit delete. I then ran Bevel Reflect Logo on it with a silver e-map I have.
