It is currently Thu Aug 27, 2026 9:21 pm
 Post subject: James Sambrook Planet Render (Help)
PostPosted: Thu Jun 06, 2019 12:03 pm  (#1)
Hi everybody. I have this script "Planet Render" from James Sambrook and I remember it used to work perfect with Gimp 2.8. But with Gimp 2.10 the filter setting "Sun orientation (degrees) it's not working, it's not rotating. After it had finish the process, it will leave a "Floating selection". Can any of the Experience coders here fixed this scripts, I had upload the script file>. Thank you in advanced. :)
Planet_Setup.scm [7.79 KiB]
Downloaded 228 times
 Post subject: Re: James Sambrook Planet Render (Help)
PostPosted: Fri Jun 07, 2019 9:51 am  (#2)
Hi Pocholo
All script-fu coders are probably retired and they are not interested in Gimp... :rofl
Interesting script so I tried to upgrade :roll:
Planet_Setup.zip [2.65 KiB]
Downloaded 281 times
PostPosted: Fri Jun 07, 2019 1:15 pm  (#3)
Thank you, thank you, thank you, MareroQ :jumpclap. I appreciate your time and effort. Even though this is an old script, I still use it when I´m doing a quick Space project. Have a wonderful day. :)
