It is currently Fri Aug 28, 2026 11:21 pm
 Post subject: What is the procedure name for "crop to contents"?
PostPosted: Fri Jun 21, 2019 11:21 am  (#1)
I'm trying to write a python-fu plugin to batch crop all layers to contents. According to the documentation in the Procedure Browser, plug-in-autocrop-layer takes (INT, IMAGE, DRAWABLE). If I put in 3 parameters it throws a TypeError: wrong number of parameters. If I put 2 parameters, (INT, layer) it throws a TypeError: wrong parameter type. Could you please give some pointers on what am I doing wrong? Following is the code:
def trim_layers(image, layer):
    trim_layer_group(image.layers)
def trim_layer_group(group):
     for layer in group:
        if pdb.gimp_item_is_group(layer):
            trim_layer_group(layer.layers)
        else:
            pdb.plug_in_autocrop_layer(0, layer)
Cheers!
 Post subject: Re: What is the procedure name for "crop to contents"?
PostPosted: Fri Jun 21, 2019 11:36 am  (#2)
Ignore first parameter, not used for python plug-ins.
Just use image, drawable.
PostPosted: Fri Jun 21, 2019 1:04 pm  (#3)
Thanks.
Now I'm not sure what the parameters are. Which image? gimp_item_get_image(layer)? The Image object passed to the main() function? The layer?
I've tried several combinations and none of them work.
PostPosted: Fri Jun 21, 2019 1:20 pm  (#4)
the image of the one you're try to crop of.
usually it's the called image passed in from running plug-in
and the layer is the drawable you're trying to crop as well.
image is the image that the layer belongs to that you're trying to crop.
from your code you have image.layer then you're calling another function that deals with image.layers.
so I would guess you'd want to pass in the image to that function as well and use that as your image parameter.
something like
def trim_layers(image):
    trim_layer_group(image, image.layers)
def trim_layer_group(image, group):
     for layer in group:
            trim_layer_group(image, layer.layers)
        else:
            pdb.plug_in_autocrop_layer(image, layer)
TinT
PostPosted: Fri Jun 21, 2019 3:09 pm  (#5)
hrodgair wrote:
Thanks.
If your registration parameters start with a PF_IMAGE and a PF_DRAWABLE, (so the plugin function is "somefunction(image,drawable, ....)" ) then when the plugin is called the current image and its active drawable (layer, mask or channel) are automatically set in the first argument to the function.
PostPosted: Sun Jun 23, 2019 2:06 am  (#6)
That I understand. But I'm iteratinig over all layers, to crop them, and I'm not sure what arguments I should pass to the autocrop function. Obviously I have to pass the layer, but is it the image or the drawable? In either case, what is the other argument, then?
PostPosted: Sun Jun 23, 2019 2:54 am  (#7)
If you iterate over all layers, the image argument is the same each time, and the second is each layer in turn:
for layer in image.layers:
Of course in that case you don't need to be passed a layer as part of the plugin arguments, just declare the PF_IMAGE argument and skip the PF_DRAWABLE.
PostPosted: Sun Jun 23, 2019 6:22 am  (#8)
Great! Thanks a lot for your help.
