It is currently Fri Aug 28, 2026 11:21 pm
 Post subject: Psychedelic rel 0.03 does not work (Solved)
PostPosted: Fri Jul 05, 2019 3:19 pm  (#1)
Does anybody have a updated version of the Script "Psychedelic rel 0.03" for Gimp 2.10 The one I have fro Graechan is giving me an error "Error: eval: unbound variable: LINEAR". If anybody have a updated version for 2.10, and wouldn't mine sharing it, i'll appreciated.
 Post subject: Re: Psychedelic rel 0.03 does not work
PostPosted: Fri Jul 05, 2019 3:47 pm  (#2)
I had to download the old script from waybackmachine (gimpscripts 2014/11) because I don't have it.
Fixed LINEAR and plug-in-displace. Ran on default settings, does it look okay? Script attached.
Psychedelic.scm [33.8 KiB]
Downloaded 218 times
PostPosted: Fri Jul 05, 2019 4:09 pm  (#3)
Thanks a lot Nidhogg. Men, you guys are awesome!
 Post subject: Re: Psychedelic rel 0.03 does not work (Solved)
PostPosted: Sat Jul 06, 2019 7:24 am  (#4)
