It is currently Wed Nov 25, 2026 5:18 pm
Post new topic Reply to topic  [ 54 posts ]  Go to page 1, 2, 3  Next
 Post subject: Paint Paths in Steps Plug-in
PostPosted: Wed Jul 10, 2019 12:01 am  (#1)
:edit More details instruction. You can change your hand image, your own art and define where the pen tip is.
:movedn Plug-in Download.
:keybdtype Video Demo
You know those animated videos with a hand drawing/doodling things for Youtube videos... Like instructional, or even internet marketing videos...
Now you can basically create such animation:
sample output version 4:
sample output version 5:
Version 5 allows you to paint on an existing mask so that you can reveal finished art (or coloring).
Version 7.
Options to add animation of transitioning IN (from outside of whiteboard), BETWEEN shapes, and OUT (of whiteboard at the end).
 Post subject: Re: Paint Paths in Steps Plug-in version 4/5
PostPosted: Wed Jul 10, 2019 12:52 am  (#2)
Of course, you can replace the drawing hand with a hand that's holding a coin and you create "Scratch and win" animations.
PostPosted: Wed Jul 10, 2019 5:24 am  (#3)
Well done Tin, this is very cool and useful too.
PostPosted: Wed Jul 10, 2019 8:29 am  (#4)
Thanks for trying it racer-x! :D
PostPosted: Wed Jul 10, 2019 10:25 am  (#5)
Cool update! :tyspin
PostPosted: Wed Jul 10, 2019 10:29 am  (#6)
Thanks for trying it Nidhogg!
PostPosted: Wed Jul 10, 2019 5:14 pm  (#7)
I had some time to play with this again. It's a great plugin for washing windows.
PostPosted: Wed Jul 10, 2019 7:57 pm  (#8)
that's one thick layer of dirt on the window
PostPosted: Thu Jul 11, 2019 5:45 am  (#9)
OK, last one. This makes writing with a feather pen a breeze.
PostPosted: Thu Jul 11, 2019 6:05 am  (#10)
racer-x, I hope that's not your windshield ;)
 Post subject: Re: Paint Paths in Steps Plug-in version 4/5...7
PostPosted: Thu Jul 11, 2019 3:16 pm  (#11)
Version 7.
PostPosted: Thu Jul 11, 2019 7:07 pm  (#12)
Excellent upgrade! No need to delete frames anymore.
PostPosted: Thu Jul 11, 2019 8:47 pm  (#13)
I started a topic for people to contribute to public domain animations and video makers can use...that's the idea anyways.
I started with some animations that any can string together to come up with their own.
https://gimplearn.net/viewtopic.php?p=27871#p27871
PostPosted: Fri Jul 12, 2019 5:12 am  (#14)
Awesome update :yes Thanks again Tim.
One handmade path, based on Bickley Script. Because the Hershey plug-in creates a mess.
PostPosted: Fri Jul 12, 2019 9:01 am  (#15)
You have such nice hand writing :D
PostPosted: Fri Jul 12, 2019 10:45 am  (#16)
PostPosted: Sun Jul 14, 2019 10:06 pm  (#17)
Nice quill pen work racer-x and Nidhogg.
Nidhogg, Your awesome is lovely handwriting.
The only Scriptina font I've come across is this one
https://www.dafont.com/scriptina.font
which isn't the same, did you adapt it or is there another Scriptina font?
I'll just park this here:
PostPosted: Mon Jul 15, 2019 1:41 am  (#18)
Nice Volkswagen Beetle teapot. The font was Bickley Script, not Scriptina.
PostPosted: Mon Jul 15, 2019 5:38 pm  (#19)
Excellent work on that Beetle, teapot. I decided to draw a 69 Charger Daytona.
PostPosted: Mon Jul 15, 2019 9:28 pm  (#20)
Nidhogg, Very cool horror writing in blood. Thanks for the font name, it's a keeper.
racer-x, Great drawing, it really looks done by pencil. Have to admit the Beetle was done by autotrace centerline tracing and then lots of path processing using Ofnuts path tools. The original is from a font.
