It is currently Mon Aug 10, 2026 8:39 am
 Post subject: Help for ShellOut.py (and relative paths )
PostPosted: Mon May 16, 2011 11:47 am  (#1)
RobA told time ago that the script should accept relative paths but for me didn't worked
I may have goofed somehow but i tried long with no joy...
To clear the point here a screenshoot of my "ShellOut" folder
ShellOut.py should call xnview.exe that is in a subfolder of the same folder
PM-ShellOut.py is a different version , modified to call a font manager.
that again is in a subfolder of the same folder
the idea is that if the path are relative, i may transfer easily everything without having to edit again all paths
in the py flie
i zipped the 2 script , ShellOut give me a error ,i suppose for the path
PM_ShellOut apparently doesn't work at all ,meaning that doesn't show up in the menu
if may help i may upload the whole folder
 Post subject: Re: Help for ShellOut.py (and relative paths )
PostPosted: Mon May 16, 2011 9:34 pm  (#2)
Should work.
I just tried this:
  ["MS Paint", "\"..\\..\\..\\..\\WINDOWS\\system32\\mspaint.exe\"", "bmp"],
and it worked OK. That is the path to mspaint relative to the plugin folde
Try something like "\"XnView\\xnview.exe\""
or maybe "\".\\XnView\\xnview.exe\""
-Rob A>
PostPosted: Tue May 17, 2011 10:27 am  (#3)
Thank my ADSL broke when i was editing my message and went back just now, i will try again following your suggestion
PostPosted: Wed May 18, 2011 10:51 am  (#4)
i tried both , no joy :gaah
not sure if the error message may be useful
i copy here my version of the script anyway i changed only the xnview entry (and i tried only with xmview option )
and the menu location...
And the other script the version you simplified to call a font manager did not even show in the menu :bawl
I tought the best way to understand what went wrong was upload a zip with everything:
once unzipped should be sufficent to add from gimp a path from preference to the folder to make it work...or hopefully to see what went wrong
LINK http://www.megaupload.com/?d=O04UKTRZ
PostPosted: Wed May 18, 2011 11:34 am  (#5)
I am curious about the FM_Shellout.py script.Would you mind sharing it?
I didn't know that was possible to call out another font manager through Gimp.
PostPosted: Wed May 18, 2011 12:42 pm  (#6)
It is inside the zip,but didn't work, here may be a error of copy and paste, the script didn't even show up in the gimp menu
PostPosted: Wed May 18, 2011 12:55 pm  (#7)
originally i asked to call the gimp gimp theme switcher, then i tought was handy to call a font manager
Differ from the original shell out script because no image has or data has to be send and returned back, so is more simple
i just recover the original from the message of RobA i post below (just in case the copy i included in the zip in the first message went somehow mangled
#!/usr/bin/env python
from gimpfu import *
import shlex
import subprocess
import os, sys
def plugin_main(image, drawable):
# Command line - Change to match where the theme switcher binary is located
command = "\"C:\\Program Files\\GTK2 Themes\\xxxxxxx.exe\""
args = shlex.split(command)
# Invoke external command
pdb.gimp_progress_set_text ("run XnView...")
pdb.gimp_progress_pulse()
child = subprocess.Popen(args, shell=False)
child.communicate()
register(
"python_fu_runprog",
"Run a program",
"Run a program",
"Rob Antonishen",
"Copyright 2011 Rob Antonishen",
"2011",
"<Image>/Edit/GTK Theme Switcher",
plugin_main,
main()
but i cannot even see it in the menu
PostPosted: Wed May 18, 2011 1:17 pm  (#8)
I am not sure what you are trying to do other than call the font manager and XnView through the same folder, but here is what i did.
I added the folder to C directory, and renamed it "shell_out_Font_frenzy"
And added it to Shellout like this
  # Where what gets executed is command fileame so include and flags needed in the command.
  programlist = [
  ["XNView", "\"C:\\Program Files\\XnView\\xnview.exe\""],
  ["NeoPaint", "\"C:\\Program Files\\NeoPaint\\NeoPaint.exe\""],
  ["ASCII Gen", "\"C:\\Documents and Settings\\Compaq_Owner.FAMILY-ROOM\\Desktop\\DESKTOP\\Full Programs\\ascgen2-0.9.6\\Ascgen dotNET.exe\""],
  ["Anamorphe Me", "\"C:\\Program Files\\AnamorphMe\\AnamorphMe.exe\""],
  ["Dog Waffle Pro", "\"C:\\Program Files\\Project Dogwaffle Professional\\dogwaffle.exe\""],
  ["Photo Shop CS5", "\"C:\\Documents and Settings\\Compaq_Owner.FAMILY-ROOM\\Desktop\\DESKTOP\\Full Programs\\PhotoshopPortable\\App\\PhotoshopCS5\\Photoshop.exe\""],
  ["Imagelys", "\"C:\\Program Files\\Imagelys Picture Styles 7\\ips.exe\""],
  ["MS Paint", "\"C:\\WINDOWS\\system32\\mspaint.exe\""],
  ["Deep Paint", "\"C:\\Program Files\\DeepPaint\\deeppaint.exe\""],
  ["Font Frenzy", "\"C:\\shell_out_Font_frenzy\\shell_out\\FontFrenzy\\FontFrenzy.exe\""],
It works as long as you have a layer in your document.
PostPosted: Wed May 18, 2011 1:19 pm  (#9)
Oh okay i see what you are trying to do now.
Every time i try and add two different call python scripts only one will show up in the menus.Must be something in the script calling the same two values maybe?
PostPosted: Wed May 18, 2011 1:42 pm  (#10)
The basic thing i was trying to do is make the script working with relative path, so i may use with my portable gimp
I can't use absolute paths because the HD may be C or even D and there is no way to predict the letter of the USB drive
so i can't indicate path as in "\"C:\\Program Files\\Project Dogwaffle Professional\\dogwaffle.exe\""
But if the absolute position may change the relative path will be always the same,
If the content of the folder (see screenshot in first message ) is no changed , whatver that folder will be moved or copied the relative path,that are f for subfolder(s) of the same directory, the same folder were is the script will remain always the same
...so path as "./XnView/ xnview.exe " should work (or //XnView//xnview.exe or
".//XnView//xnview.exe") SHOULD work
BUt in practice they don't work maybe for a my dumb error , anyway i need help to find the error , if in my paths or in the script or ...
ah happens to you ,too
the scripts have 2 different procedure names , and 2 different registry paths so should not conflict
anyway i cannot use neither , one because give me error with relative paths, and the other because do not even show up
PostPosted: Thu May 19, 2011 7:22 am  (#11)
@PhotoComix
I can't check everything as your link to the zip is in a banned place from behind the corporate firewall :gaah
But you have a mistake in the code you've posted. You have a square-bracket pair missing from the register block. It should be:
register(
   "Run a program",
   "Run a program",
   "Rob Antonishen",
   "2011",
   plugin_main,
You also need to be sure that the "python_fu_runprog" is unique to each register block in ALL the python plug-ins. If you have the same thing in more than one of the plug-ins then you will only see one of them in the menu (the last one that gets loaded).
Kevin
PostPosted: Thu May 19, 2011 8:11 am  (#12)
Kevin thank, i will correct the bracket, about the name i believe "python_fu_runprog" is unique the other script is called ""python_fu_shellout", and i can't see other with conflicting names
sorry you can't get the zip there is some other place where i may upload that will be no blocked by the firewall ?
anyway from the screenshoot the architetture should be visible
Do the error message i posted refer to a wrong path or was about something else ?
and bigger problem for me which should be the correct relative path?
i still get error with both the path indicatewd by RobA in his reply
PostPosted: Thu May 19, 2011 9:33 am  (#13)
PhotoComix
Don't worry about putting your zip file somewhere else, I could get to it when I am at home.
But I think I know why it's not working with relative paths. The problem with relative paths is that they are relative to the current working directory. On Linux that may be the plug-ins directory, but on Windows it's not so simple.
If I start GIMP by double-clicking the executable C:/Program Files/Gimp-2.0/bin/gimp-2.0.exe, then the working directory is C:/Program Files/Gimp-2.0/bin/ and the paths are relative to there.
If I start GIMP from a short-cut, where the Start in field is set to "%USERPROFILE%\My Documents\My Pictures", then that is my working directory and paths are relative to that directory.
You will need to find out where the current working directory is and specify the relative path from there.
To find out the current working directory I added a line to your code before " # Invoke external command":
  raise NameError(os.getcwd())
Which generates an error:
NameError: C:\Program Files\GIMP-2.0\bin
Personally I'd opt to change the ShellOut plug-in to remove the paths and do it the same way the Photivo people did - first time prompt the user where the executable is and save the answer in gimprc (see the Gimp to Photivo section of http://photivo.org/photivo/download_and_setup/gimp)
Kevin
PostPosted: Thu May 19, 2011 10:02 am  (#14)
But I think to know why it's not working with relative paths. The problem with relative paths is that they are relative to the current working directory.
You hit the nail in the head !!
That was my first doubt try to use relative path:
relative to WHAT ?
But then i hoped that the most simple and logic , relative 1 of the 2 extremes , in this case relative to ShellOut.py and leading to the app to call so " ./XnView/xnview.exe"
(or "/XnView/xnview.exe" or ".//XnView//xnview.exe but anyway the starting point of the path was the active script that had to use the path )
I had some doubts (as...maybe was Python.exe to execute the script so the path should start from python.exe ?) but i was hoping for the best...i mean what the sense of a relative path if is so hard to guess know , to WHAT is relative ?
I really hope to clear this point and to solve, i am stuck here from a couple a weeks
PostPosted: Fri May 20, 2011 6:55 pm  (#15)
:bump
still lost with the realative path :gaah
PostPosted: Fri May 20, 2011 7:24 pm  (#16)
PC are you trying to run Font Frenzy so Gimp will grab the font you want in Font Frenzy and use it?
Like Dynamic Text?
I like the idea of just being able to see the fonts bigger (that's nice).A much larger preview.
Using Font Frenzy called through the original ShellOut works for better previews of the font you plan to use.
I guess i am not still sure what you are trying to do.
Themes i can understand because those are built for Gimp, and other GTK programs.(Inkscape for instance)
Did you actually get Themes to work yet?I couldn't through this script.Only themes 1.0 works for me.
Sorry i do not understand what you are trying to accomplish.
PostPosted: Fri May 20, 2011 7:56 pm  (#17)
In GNU/Linux, any path which does not start with slash ("/") is relative. If it starts with a slash then it is absolute, more commonly referred to as "fully qualified". Note that I am referring to the expanded pathname, if your pathname starts with a variable (e.g., $HOME/.gimp-2.6) then it is the pathname that results after the value of $HOME is substituted that determines whether the path is relative or fully qualified.
For GIMP, all relative paths are relative to the working directory at the time GIMP is started. If you are starting GIMP from a desktop icon then this working directory is usually specified as a property of the icon (in Windows, I believe there is a shortcut preference called "Start program in..." or somesuch).
It is possible that the ShellOut plug-in is changing the working directory before searching for the files (but I doubt it).
PostPosted: Sat May 21, 2011 2:35 am  (#18)
This is getting very confused, let's see if a picture can help:
Are my assumptions correct? If so then the relative paths are from the GimpPortable.exe:
"App\\gimp\\lib\\gimp\\2.0\\plug-ins\\FontFrenzy\\FontFrenzy.exe"
and
"App\\gimp\\lib\\gimp\\2.0\\plug-ins\\XnView\\XnView.exe"
I will say that I can't try this as I don't have Python installed with GimpPortable (is this possible?)
I also got the zip file downloaded and FM_shellout.py has a number of mistakes:
The missing [], line from the register block.
The command
  command = "\".\FontFrenz\FontFrenzy.exe\""
should have had double backslashes (see above) and the directory name is spelt wrong: FontFrenz
I think you should have:
  command = "\"App\\gimp\\lib\\gimp\\2.0\\plug-ins\\FontFrenzy\\FontFrenzy.exe\""
Kevin
PostPosted: Sat May 21, 2011 2:51 am  (#19)
If that is all you need, just delete the C: -- your path will be fully specified to the particular drive you are on (unless Microsoft has changed things recently).
@Paynekj, why are Xnview and Fontfrenzy in the GIMP plug-ins folder? They are not plug-ins.
PostPosted: Sat May 21, 2011 3:55 am  (#20)
Because I've got the impression from the original post that's where PhotoComix has put them on the USB drive.
Kevin
