It is currently Sat Aug 29, 2026 11:35 am
 Post subject: Felimage Noise Plugin v 0.1.1 Win10_and_LINUX_64bit.
PostPosted: Mon Nov 04, 2019 3:11 pm  (#1)
This is one of my favorite plugins.
(and since I have a computer with Win10_64bit so I built the GIMP compilation environment - and I can go back to compiling the old plugins).
Felimage Noise Plugin v 0.1.1 for the GIMP: http://fimg-gmplugins.sourceforge.net/
FelimageNoise is a GIMP plugin, originally developed, to generate noise patterns, but with feature sizes larger than a single pixel.
It can generate tileable textures, textures for use in spherical mapping.
It can use foreground/background colors, gradients and independent RGBA channels or warp an image.
It implemens several noise functions, such as FBM (Fractal Brownian Motion) and Multifractal textures,
with complete control, to allow for animation of noise (useful to generate animation frames), as well as complete presets management.
in menu GIMP: Filters/Render/Felimage/Noise...
In my compilation (in attachment)
Filters/Render/Pattern/FelimageNoise...
Felimage Noise Plugin v 0.1.1 Win10_64bit.zip [320.11 KiB]
Downloaded 421 times
 Post subject: Re: Felimage Noise Plugin v 0.1.1 Win10_64bit
PostPosted: Mon Nov 04, 2019 4:24 pm  (#2)
Thank you for your continuous Gimployments MareroQ.
Never tried this plug-in but looks interesting. Will play on Windows at work.
PostPosted: Mon Nov 04, 2019 4:58 pm  (#3)
Here a linux (64 bit) contribution
Un-zip Put the folder felimage and plugin felimage-noise in your plug-ins folder ~/.config/GIMP/2.10/plug-ins Should be executable but check anyway.
Shows in Filters -> Render -> Felimage -> Noise Then set the path to the /felimage/noise folder in the Presets tab.
Works in 'buntu (and Mint ) Good chance it works in other distros.
felimage-noise.zip [181.77 KiB]
Downloaded 333 times
 Post subject: Re: Felimage Noise Plugin v 0.1.1 Win10_and_LINUX_64bit.
PostPosted: Mon Nov 04, 2019 6:08 pm  (#4)
Thank you MareroQ for this great plugin.
Up and running on Windows 10 Pro 64 bit Gimp 2.10.6
Will play further later in the day.
You are doing great work, really appreciated.
P1937
PostPosted: Mon Nov 04, 2019 11:33 pm  (#5)
P1937
PostPosted: Mon Nov 04, 2019 11:54 pm  (#6)
MareroQ - thanks for this; but just FYI and much to my surprise, as I was re-starting GIMP to include the plug-in, my AVG cyber security window popped up and told me "You have discovered a very rare file". The message then advised that the file was being sent to AVG HQ for 'interrogation' and a response will be available within 57 minutes. Big Brother maybe :hehe
PostPosted: Tue Nov 05, 2019 12:59 am  (#7)
@Rich2005
Thank you for expanding the thread with the Linux version (it's very good that it's in one topic).
@Hi Oldmangrumpy.
My antivirus (AVAST 19.8.2393) behaves similarly.
This significantly delays the compilation (or first run) time - however, the information received "File is safe" is accompanied by thank you for enlarging the database. :hehe
What is the AVG response?
PostPosted: Tue Nov 05, 2019 3:21 am  (#8)
Thank you for the Linux version rich2005! :bigthup
Love the results, this has lot of options, need to play more later or I'll get fired :hehe
Skin preset, autumn green gradient, added half round bevel on the lizard silhouette.
PostPosted: Tue Nov 05, 2019 4:45 am  (#9)
Hey Nidhogg, I really like that outcome. Looks like you are still thinking about imprinting :)
This would look good with text as well. :bigthup
PostPosted: Tue Nov 05, 2019 11:10 am  (#10)
Thanks Tas_mania. Yes, I'm still thinking about imprints and engravings, have unfinished tut for engraved aluminium plate.
Added text, not same style though...it's a movie poster :hehe
First I thought about "Liana Lizard (Indiana Jones logo style) and the hunt for lost tale." but the freeware Indy font isn't that nice and I haven't played with Gimp tools that you can use to envelope text like it is in the Superman or Indiana Jones logos.
PostPosted: Sun Dec 08, 2019 7:08 pm  (#11)
I found the plugin here for older gimp versions http://fimg-gmplugins.sourceforge.net/docs.php. I put it first in my plugin user folders, then in the program files folder trying to get it to show up in my 2.8.22 gimp. Windows 10.
It didn't, so I then tried to open the exe on my desktop and get an error that I am missing libgimp-2.0.0.dll.
Will getting this file fix it? If so, where can I get it?
PostPosted: Sun Dec 08, 2019 8:59 pm  (#12)
As a Windows 10 user, where does the plugin go in order for it to work in gimp?
PostPosted: Sun Dec 08, 2019 10:35 pm  (#13)
For Win and Gimp 2.8 there is only the 32bit version.
Location of the standard (*.exe) plugin - in the plug-ins folder.
PostPosted: Sun Dec 08, 2019 10:44 pm  (#14)
According to your first post, you attached a windows 10 64bit file. Also will it work for Gimp 2.10.14?
PostPosted: Sun Dec 08, 2019 11:03 pm  (#15)
As for me in Gimp 2.10.14 Win 10_64 bit works very well :yes
PostPosted: Sun Dec 08, 2019 11:15 pm  (#16)
For me the plug-in can be found here:
Filters>Render>Pattern>FelimageNoise and it works. :)
PostPosted: Sun Sep 27, 2020 4:54 am  (#17)
Just exploring the textures generator for Custom Font purposes since Mahvin posted the plug-in on Gimp Scripts.
Somehow missed the original re-release here.
Thanks MareroQ...
PostPosted: Sun Sep 27, 2020 5:58 am  (#18)
Did someone try to "call" it from inside a script?
How can the "parameters string" (mentioned in the pdb) be build?
Any example?
PostPosted: Mon Sep 28, 2020 4:15 pm  (#19)
Hi.
I think it is sufficiently described:
http://fimg-gmplugins.sourceforge.net/devel.php
PostPosted: Mon Sep 28, 2020 11:32 pm  (#20)
Thanks a lot, I will try.
