It is currently Fri Aug 28, 2026 8:42 am
 Post subject: Custom Font Metallic Effects for Gimp 2.10
PostPosted: Mon Nov 11, 2019 8:02 am  (#1)
Custom_Font_Metallic_Effects_001.zip [10.61 KiB]
Downloaded 353 times
An extended custom font version of an older plug-in for adding metallic style effects. Full details and help pdf available on GimpLearn.
 Post subject: Re: Custom Font Metallic Effects for Gimp 2.10
PostPosted: Mon Nov 11, 2019 11:56 am  (#2)
This looks really nice.
Thank you Skinnyhouse.
PostPosted: Mon Nov 11, 2019 4:38 pm  (#3)
You are welcome Wallace and thank you for your support.
PostPosted: Tue Nov 12, 2019 1:04 am  (#4)
@Skinnyhouse
A very interesting and versatile plugin for the metal effect.
A lot of options (I have tried probably 1% for now).
Understandably, it was created for Custom Font and when the layer name is not a letter, this is a message:
UnboundLocalError: local variable 'first_char_layer_name' referenced before assignment
Hence the request:
- generic version (Alpha to Logo) for any layer name,
- save the settings used in any option: as a new layer, as a txt file (e.g. like Apply and Save/Load Preset Script for Layer Effects by TT)
PostPosted: Tue Nov 12, 2019 2:59 am  (#5)
Thank you M.
Yes, as you say, it is only intended for Custom Fonts and I was hoping that no-one would look under the hood before the next version so that I could tidy up the rather wasteful code.
It was created, with the smaller character image size in mind, and so I am not sure about its effectiveness when working with larger images - ie banding, artifacts etc. I normally rename any non-character layer to custom font convention e.g. A.png if I want to use a custom font plug-in for other purposes - but a suitable option is quite feasible. Not familiar with TTs text file presets although I did use something in my Lighting Effects custom font plug-in - so I will have a look when I get a chance.
PostPosted: Tue Nov 12, 2019 6:34 am  (#6)
Thank you for the quick reply.
It's always worth waiting for a good plugin (even for a long time...).
PostPosted: Tue Nov 12, 2019 1:35 pm  (#7)
Custom_Font_Metallic_Effects_001b.zip [10.79 KiB]
Downloaded 271 times
One for you MareroQ:
This seems to work on the active layer - not tested it much - in non-custom font mode if you set the last option to No.
PostPosted: Tue Nov 12, 2019 5:53 pm  (#8)
Thank you so much for your instant adaptation. :tyspin
PostPosted: Fri Nov 15, 2019 9:52 am  (#9)
No probs.
Although I have just found and sorted problems with the verdigris texture with the active layer option.
In your version it works correctly only when a texture layer is above the active layer in the layer stack.
