It is currently Fri Aug 28, 2026 2:53 am
 Post subject: APNG (animated PNG) plug-in for Gimp 2.10 Windows64x
PostPosted: Wed Nov 20, 2019 3:28 am  (#1)
Note! Apng is deprecated format, Gimp 2.10 supports webp animations out-of-the-box.
APNG plug-in for Gimp 2.10 Windows 64x.
I haven't seen this for 2.10 so I'll post it for anyone who wishes to try out.
It doesn't overwrite anything, but be careful.
Installation:
1. Copy the dll file (libpng15-15.dll) to the Gimp 2\bin directory (C:\Program Files\Gimp 2\bin)
2. Create a new folder, called file-apng. Copy the exe file (file-apng.exe) in that folder and drop it to plug-ins folder (C:\Program Files\Gimp 2\lib\gimp\2.0\plug-ins)
3. Copy the plug-in-file-apng.ui file to the Gimp 2.10 ui directory (C:\Program Files\Gimp 2\share\gimp\2.0\ui\plug-ins).
4. Restart Gimp.
Create your animation layers.
File: Export as...select file type by extension from the list, PNG + APNG.
Skip the "extension mismatch" alert. Select compression level and make sure to tick on animation option.
Quick test.
Don't thank me, it's old apng build by Partha from 2011.
apng-Gimp-2.10-64bit.zip [258.78 KiB]
Downloaded 3285 times
 Post subject: Re: APNG (animated PNG) plug-in for Gimp 2.10 Windows64x
PostPosted: Fri Nov 22, 2019 2:57 am  (#2)
Update2: But how can I set the speed of layer changes? Now it "flyes" over my 8 pictures :) every 3000ms it should change to next layer for example. Is this possible?
Update: I worked!!! I edited every layer and clicked "layer to image size" and also set every layer mode to "normal" (some where "normal (v)")... after that it worked!!!
I tried it but after clicking save I get this warning
PostPosted: Fri Nov 22, 2019 6:30 am  (#3)
You can change frame timings either manually, by editing the layer attributes or by using a plug-in.
Combined mode:
Layername (200ms)
Replace mode:
Layername (200ms) (replace)
Read step 5 here:
https://www.gimp.org/tutorials/Simple_Animations/
PostPosted: Sat Nov 23, 2019 3:10 pm  (#4)
I didn't know Gimp had native support for webp, thanks for that. Unfortunately this site won't let webp upload. Imgur also won't let upload webp. Does anyone know of a free image hosting site that allows webp upload?
PostPosted: Sun Nov 24, 2019 12:47 am  (#5)
Since WebP's Google format, my bet is Google Drive can host such file types. First 19Gs at Google are free. Personally have not used Google Drive. I do know OneDrive can host, pretty much, all types of files, but it may not see WebP files as images (ie, no preview). :)
