It is currently Sat Aug 29, 2026 7:16 am
 Post subject: Early stage new version of Custom Font Layers with Fixed Margins
PostPosted: Thu Dec 05, 2019 6:55 am  (#1)
I have been thinking about this for some time - and hadn't realised that MareroQ had produced such an excellent set of plug-ins for handling unicode characters.
Anyway here are some of the results that I have had using the highlighted option...
The layers on the left show the star characters generated and then put through the metallic filter.
And a couple of star layers results. Metallic effects and Shine effect...
 Post subject: Re: Early stage new version of Custom Font Layers with Fixed Margins
PostPosted: Fri Dec 06, 2019 1:40 am  (#2)
Hi Skinnyhouse.
Is this weird (but beautiful)?
At the same time:
You - add Unicode to Font_Metallic_Effects.py
I - I am thinking about adding Font_Metallic_Effects to Unicode_to_shape (so I asked for the option of extended application with "ordinary" layers).
By the way, one more request (long-term?):
if you add foreign characters can you add polish characters?
polish_case = unichr(260) + unichr(262) + unichr(280) + unichr(321) + unichr(323) + unichr(211) + unichr(346) + unichr(377) + unichr(379)
polish_case += unichr(261) + unichr(263) + unichr(281) + unichr(322) + unichr(324) + unichr(243) + unichr(347) + unichr(378) + unichr(380)
(and probably for all languages instead of PF_TOGGLE one PF_OPTION).
I will follow the development of your new plugin with interest.
Good luck.
PostPosted: Fri Dec 06, 2019 3:02 am  (#3)
Adding Polish characters a pleasure - even if the experimental never makes it - scary emoji wins.
PostPosted: Fri Dec 06, 2019 2:37 pm  (#4)
Making progress with emoji - although most other custom font filters do not recognise the results.
PostPosted: Mon Dec 16, 2019 5:20 pm  (#5)
Thank you so much for granting my request.
You are a specialist in fonts - I admire the constantconstant development of this issue. :yes
PostPosted: Fri Dec 20, 2019 2:21 pm  (#6)
MareroQ:
Polish characters and kerning (along with French, German, Italian and Spanish) included in this monster custom font over on GimpLearn.
Custom font with accented characters
PostPosted: Fri Dec 20, 2019 4:17 pm  (#7)
I'm enjoying,
what seems to be a serious passion and enthusiasm,
for custom font creation.
I too,
once had a pressing urge for this same thing.
Unfortunately,
depending on how one looks at it.
I've gone on to other "pressing urges".
PostPosted: Sat Dec 21, 2019 7:41 am  (#8)
Thank you for the kind words Wallace.
Some may think it an obsession - I think of it as an back-itch that I cannot quite reach well enough to scratch, if you pardon the image.
Enjoy the season.
